Old 07-02-2007, 11:33 AM
Trevlyns Trevlyns is offline
Senior Citizen/Member
Rep: 461 Posts: 689
Weight of Plywood
Hi guys
Does anybody have to hand the approximate weight of plywood? I’m looking for 6 and 9 mil either per square meter/foot or standard 8 X 4 sheet.
Thanks in anticipation
Take care!
Trev F – Amateur designer and part-time layabout.
Old 07-02-2007, 11:54 AM
Steve B Steve B is offline
Rep: 10 Posts: 17
Trev,
6mm usually 2 - 2.4 kg/sq mtr depending on type. 9mm half as much again. www.marineply.com has lots of info.
Cheers
Steve
Old 07-02-2007, 11:57 AM
Rep: 461 Posts: 689
Much obliged Steve. Thanks for a quick reply
Old 07-03-2007, 12:41 PM
Rep: 2891 Posts: 8,792
Species is quite important, which did you have a question for? An example would be two BS 1088 sheets, one of Okoume, the other of Mercanti which will be 20% heavier. It may not seem like much, but could be substantial for calculations in small craft design or the hull shell weight. In other words, a stitch and glue design displacing 2,000 pounds could be 2,400 pounds if you're not careful. In small craft, excess weight is a performance killer.
Old 07-03-2007, 06:15 PM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
One 6mm Okume I had was 2.8kg/m2, another 9mm spruce core with oukume outside was 4.7kg/m2.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
epoxy weight rturbett Fiberglass and Composite Boat Building 4 11-05-2006 01:39 AM
wet weight vs dry weight of Diesels... spank Boat Design 3 10-20-2006 04:16 AM
Weight 95Capri Powerboats 0 06-28-2006 12:58 AM
Average Human Weight, Safe Excess Weight, &c. Free Pirate Boat Design 12 03-14-2005 02:40 AM
Weight Summary UNOSNAME Boat Design 0 10-22-2004 06:52 PM
