Old 08-06-2008, 11:12 AM
GWB GWB is offline
Rep: 10 Posts: 67
Warped cabin sole
I have a teak and holly sole that is glued (epoxy I think) to plywood to form the sole. 2 of these pieces are removable to get to the bilge and water tanks.
These two pieces have warped slightly...they now have a slightly convex curve.
I think what happened was that as the boat was built in Arizona and I moved it to Oregon, the wetter climate caused the wood to absorb moisture and as the wood could not "grow" outward due to the rest of the sole hemming it in, it "grew" up.
How can I flatten it out? I tried placing the two pieces back to back and clamping them - this did straighten them out initially but then over a period of time they resumed their convex shape.
Maybe wetting them and clamping them?
Thanks for any input
Old 08-06-2008, 12:12 PM
Butch .H Butch .H is offline
Rep: 188 Posts: 631
Are they small enough to re-manufacture? easy enough to do and the quickest
Old 08-06-2008, 12:25 PM
GWB GWB is offline
Rep: 10 Posts: 67
That is an option - but it will be hard to match the other...
Old 08-08-2008, 03:17 PM
DonB DonB is offline
Rep: 10 Posts: 3
GWB-- Heres one idea but the repair may be slightly visible. Kerf the sole about halfway through maybe a little more, probably through the holly because it will be easier to match the color. Kerf once in the middle and see how much pressure it takes to flatten it. If you need to, kerf twice more between the middle and the ends on each side. It should flatten without a lot of pressure. Mix up some epoxy and wood flour and fill the kerfs then clamp it flat or put a weight on it. As the kerf closes it will sqeeze the excess out so tape the sides for easier cleanup.
If you wanted to be really fussy about it you could do some geometry to calculate the size and depth of the kerf based on the convex curve parameters. But then again sometimes trial and error is so much easier
Good Luck
Don
Old 08-08-2008, 03:40 PM
GWB GWB is offline
Rep: 10 Posts: 67
Thats a good idea....but maybe I will kerf the plywood side and then straighten and add thickened epoxy
Old 08-08-2008, 05:07 PM
Rep: 10 Posts: 3
Be very carefull there. Ideally you want to kerf on the convex side. If you kerf on the concave side you risk opening the kerf wider and splitting the wood. Closing the kerf is sort of self restraining. You absolutely do not want to do that on wood that has all parallel grain.
Don
Old 08-08-2008, 05:21 PM
GWB GWB is offline
Rep: 10 Posts: 67
Thanks for the tip Don. If I did it on the teak and basswood side, it would look very funny as the teak/basswood lines would not line up with the rest of the sole.
My other thought was to run it through a very large sander here where I work and simply sand the plywood off and then epoxy a new flat piece onto the teak/basswood.
Old 08-08-2008, 09:30 PM
Rep: 2891 Posts: 8,798
Once plywood warps, you're pretty much out of luck, without drastic measures. It was likely assembled with the usually waterproof formaldehyde based adhesives, not epoxy. These teak and holly composite panels are reasonably common now.
You could kerf the bottom side with a circular saw, roto zip or router, which will relieve the internal stresses that are causing the warping. Cut grooves about 3/4's of the way through the panel. Fill these kerfs with thickened epoxy and clamp dead flat. This will fix the problem and make it slightly stiffer.
Old 08-09-2008, 12:47 AM
alan white's Avatar
Rep: 1168 Posts: 3,270
Drill a pattern of 1/8" holes in the bottom to 2/3 through to the top surface on about a one by one inch grid. Clamp back to back with holes out and cover with damp towel and then a plastic bag for a week.
Remove and allow to dry for another few days still clamped, and then fill the holes with epoxy.
Alan
Old 09-08-2008, 11:35 AM
GWB GWB is offline
Rep: 10 Posts: 67
I ended up kerfing the bottom (plywood side) in a few places. I then clamped the pieces upside down (flat) and filled with thickened epoxy.
After a couple of days I unclamped and the pieces are almost perfect. There is still a very slight curve but it will not be noticable unless you look very hard.
Thanks for the help!
Cabin Sole as a structural member? Pylasteki Sailboats 13 12-20-2008 04:39 AM
correcting warped plywood wood is good Wooden Boat Building and Restoration 2 07-27-2007 09:21 PM
Hatch trim for cabin sole 1soleman Wooden Boat Building and Restoration 0 07-29-2006 02:54 AM
Soundproof cabin sole Willallison Materials 3 10-03-2005 09:01 PM
Monohedron vs. Warped bottom Paul Dean Boat Design 5 05-21-2003 01:03 AM
