Old 10-06-2008, 03:22 PM
GWB GWB is offline
Rep: 10 Posts: 67
Using west system epoxy to glue afromosia
I plan to use west epoxy to laminate two pieces of this wood together. Is this a good way to do it? .......do I need to thicken the epoxy and how much pressure should I apply when I clamp it?
Thanks for any help
Old 10-08-2008, 08:26 PM
Rep: 2891 Posts: 8,798
Log onto www.westsystem.com and download (they'll also mail them for free) their product and user's guides. They cover the basic materials, their uses and applications, plus general epoxy, gluing and sheathing information. Most of the major epoxy formulators offer the same thing on their sites.
To answer your questions, yep, you'll want to thicken the batch, but after wetting out the contact surfaces with unthickened goo. Epoxy requires just enough clamping pressure, to keep the parts in alignment and contact, nothing more. In fact too much pressure is bad, as it'll squeeze out the glue, starving the joint.
Old 10-13-2008, 10:35 PM
GWB GWB is offline
Rep: 10 Posts: 67
Thanks PAR
West System epoxy over D.E.R 331 epoxy bobbychuong Materials 8 10-18-2008 04:13 AM
Hull: West system and balsa (duracore) sandwich michelaos Wooden Boat Building and Restoration 1 03-22-2007 02:59 PM
West sys. glue mix Roly Fiberglass and Composite Boat Building 3 05-23-2006 02:18 AM
West system old wooden boat. jeff goldberg Wooden Boat Building and Restoration 7 10-01-2005 02:26 PM
west system vs fiberglass resin chippy Fiberglass and Composite Boat Building 4 06-04-2004 10:00 AM
