| Thanks, Gonzo please forgive my typing I'm dealing with a ton of pop-ups. Ok so just place 1/2" plywood under the plastic tank then boly in the tank and I'm good to go? should I resin the plywood? Then do the plumbing. Thanks again, Ken |
| Thanks, Gonzo please forgive my typing I'm dealing with a ton of pop-ups. Ok so just place 1/2" plywood under the plastic tank then bolt in the tank and I'm good to go? should I resin the plywood? Then do the plumbing. Thanks again, Ken |
| You have to at least resin coat the plywood. The tank needs fore and aft supports, which can be plywood bulkheads fastened or glassed to the bottom support. The hatch cover, if well fastened is adequate as top support for the tank.
__________________ Gonzo |
| Gonzo, Thanks again. Ok so You say cut an access cover in the deck. Build fore and aft bulkheads for the tank and lay glassed plywood under the tank where it contacts the bottom of the hull. Also I intend to bolt it to the stringers on the sides. sound good? |
| Remember regulations require an access plate to the fittings and fuel gage on top of the tank. Everything looks OK. Good luck.
| Thanks Gonzo I really do appreciate Your help. Regards Ken |
| Luhrs T-29 (1995) diesel inboard converted to outboard | Iya | Boat Design | 13 | 03-07-2007 06:48 PM |
| FRP Fuel Tank Fittings? | Fixin2 | Fiberglass and Composite Boat Building | 1 | 03-04-2005 01:45 PM |
| Fuel tank inquiries. | Hou-Chap | Fiberglass and Composite Boat Building | 5 | 03-04-2005 08:02 AM |
| Fuel tank placement? | Capt. Chris | Boat Design | 19 | 02-11-2005 07:46 AM |
| Fuel Tank Setup | Hiptrip | Boatbuilding | 7 | 06-10-2003 08:26 AM |
