Old 01-25-2009, 11:07 AM
CapeCodAngler CapeCodAngler is offline
Rep: 17 Posts: 17
Under deck ventilation?
I picked up a 19' fiberglass skiff. The previous owner removed a "rotten" fiberglass deck and replaced it with plywood over new PT cross members. Other than the drain plug hole in the back, there is NO VENTILATION. I have kept the plug out over the winter. There is moisture collecting inside the hull that occasionally drips out the back. Should I be concerned? Should I add inspection plates that I can leave open under the tarp? Please advose.
Old 01-25-2009, 09:48 PM
Rep: 3125 Posts: 9,408
Moisture, the proper temperatures and no ventilation are a death nails for wood. Ventilation is very important and yes, deck plates, open ended covers and the ability for air to move freely about the inside of the boat will help tremendously.
Old 01-26-2009, 05:09 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
You get inspection ports in various sizes, not too expensive and the lid screws close. If you have one or two on the deck you could leave them open when out of the water.
Pity about the plywood though. Had it been an all glass or glass and foam you wouldn't have had a worry about it.
Regards
Fanie
Water ! Just gimme water !
Old 01-26-2009, 01:28 PM
TeddyDiver's Avatar
TeddyDiver TeddyDiver is online now
Gollywobbler
Rep: 1348 Posts: 2,057
...so soon, but eventually yes..
EFI and ventilation curtis73 Sterndrives 6 11-09-2006 04:29 AM
Could this be a ventilation problem? canadianlakes Outboards 14 09-08-2006 11:51 AM
adding more ventilation James Francis DIY Marinizing 4 08-16-2006 06:38 PM
adding ventilation James Francis Fiberglass and Composite Boat Building 0 08-08-2006 05:10 PM
Do boats have enough ventilation? Elena Marketplace 1 10-21-2005 06:46 PM
