| Triple diagonal mahogany hull? First hello all!! I am complete beginner in boat building. I am looking for explanation what does it means "triple diagonal mahogany hull" and what are advantages/disadvantages of such hull. Thanks in advance, |
![]() ![]() Here you can see only the outer one of three veneer layers layed diagonal on the hull. This forms a so called "cold moulded" plywood glued and stapled in the shape of the hull. It gives a outstanding strong and durable hull and does not require a mould, like GRP. When perfect executed it is one of the best boatbuilding methods at present. Regards Richard |
| The advantages are that you can build any shape you want without having to bend thick, stiff pieces of wood. The disadvantage is that you end up fitting more pieces. However, the fit doesn´t have to be as precise as with traditional planking.
__________________ Gonzo |
| apex1 and gonzo thanks for such a fast answer!!! I am looking for these information because i am considering to buy a boat that was built like this. It was built in Germany in Burmester shipyard in 1966, and I would like to know is it hard to make repairs on such hull and what are the possible places i should look for signs of problems? |
| Get a man qualified to give you a survey on a wood hull that is cold moulded. Especially if you are paying good money to buy it. Repair of these type of hulls is much harder then a straight plywood hull. Though being mahogony,you are ahead of other woods as it rots far less than other woods but you still need a survey unless it is free. |
Burmester died from his quality, no client ever had to replace a boat. The 1940.. something, built KFK (outpost trawlers) by Burmester, are ALL in service in different duties. (except the scuttled ones of course) No, repairs on a cold moulded hull are not as easy to do as say, on a classical woody. And they cannot be done by a homebuilder without very, very much experience in wooden composites. But every (true) expert makes a repair to "as new" condition. Much easier btw. to get a wooden composite back in bristol shape (technically) than every fiber reinforced plastic hull. Regards Richard for what it is worth: I build to Burmester standards today, and it is sometimes hard to beat, even with todays technology. |
| diagonal planking | Boston | Boat Design | 153 | 11-03-2010 04:49 PM |
| Twin/Triple Outboard configuration | Adis | Outboards | 7 | 04-11-2009 01:24 AM |
| 10 M triple step monohull powerboat | Adam Younger | Projects & Proposals | 17 | 12-13-2008 10:15 AM |
| Diagonal daggerboards | weys | Multihulls | 8 | 06-09-2007 11:09 AM |
| Spray 40 Foot, Bruce Roberts Design, Mahogany (Wood), Sailing Yacht, Hull | jedclampit | Marketplace | 0 | 02-25-2006 12:43 PM |
