  #31
Old 05-05-2011, 12:18 PM
BATAAN's Avatar
BATAAN BATAAN is offline
Rep: 1090 Posts: 1,502
Having worked in various Maritime Museums, I've been exposed to a great deal of trunnel lore. The Gloucester schooners, mostly built in Essex, were trunnel fastened as were most commercial wooden sailing ships.
A plank would be hung with a few spikes, say one for every two frames, then bored and trunneled, usually right through the ceiling and wedged both ends. Locust was the preferred material. No bedding, just driven dry and tight. Of course, this is in heavy sawn frames only, not light bent frames like in boat work.
The CHARLES W MORGAN's bottom planking lasted over 150 years like this. No electrolysis or other metal diseases, but yes, a path to the heart of the frame for moisture I suppose.
Here are a couple of photos from the Story yard in Essex. In the first one the fastening crew is trunneling off a plank. In the second pic of caulkers at work on a very tight seam with a line of reaming irons. If you look closely, you'll see the occasional white pine plug over a spike head, and the rest of the fasteners being locust trunnels with a wedge.
1 1/8" minimum size, up to 1 1/2" for heavy work.
Tree Nails-screen-shot-2011-05-05-10.16.27-am.png  Tree Nails-screen-shot-2011-05-05-10.16.40-am.png
is tree sap on older gel-coat a big problem? Squidly-Diddly Fiberglass and Composite Boat Building 16 11-03-2011 11:05 PM
Outdrives tree for a very novice... Externet Sterndrives 10 10-17-2009 03:56 AM
Tree is up... Sean Herron Open Discussion: All Things Boats & Boating 2 12-22-2007 11:13 PM
Stainless Steel Deck Nails and other various nails coilnails Materials 0 07-27-2007 12:11 AM
Engineers Christmas tree Ike Open Discussion: All Things Boats & Boating 1 12-25-2006 01:58 PM
