  #31
Old 11-19-2009, 04:35 PM
Rep: 2891 Posts: 8,798
Yes, there is a measure of how far plywood can be tortured. I have a list of radiuses I can expect different thicknesses and types of plywood can reliably bend to, before rolling sheer and interlaminate issues crop up. The there's the experience thing. I can usually over bend plywood, past my guide lines, using my ear to tell me when I've reached the maximum limits of the plywood's tolerance on this particular radius.
The list can be long, because it shows each size (1/4" on up) in long and cross grain orientations, also different species and veneer counts. For example a 3 veneer sheet of Douglas fir can bend further (tighter radius) then a 5 veneer sheet. The list includes Douglas fir, Okoume, Meranti and Saple. The "compound sheets" (faced plywood) should be judged by it's interior veneers.
Anyone interested in this list, email me and I'll send a copy. Of course, I'm not responsible for any cracked or broken plywood, bent to these radiuses, other then to say, I've successfully bent pieces to these dimensions previously enough to warrant including them on the list.
  #32
Old 11-19-2009, 11:37 PM
aka Terry Haines
Rep: 1682 Posts: 2,818
Originally Posted by apex1 View Post
Let me play with it.
Richard: did you need the FreeShip file for that? It is attached if you need it. You will notice that the 2 sides of the hull are separated by about 3/8" so the plank developments allow for the keel and stems.
Dances with Turkeys
  #33
Old 11-20-2009, 11:38 AM
apex1
Originally Posted by ancient kayaker View Post
Richard: did you need the FreeShip file for that? s.
Of course Terry. thanks...
But will not do it before Monday or Tuesday Ok?
  #34
Old 12-01-2009, 07:13 PM
dskira dskira is offline
Rep: 1305 Posts: 1,363
One good way to torture the ply wood, yes plywood not foam, is to take okume ply, and soak copiously with alcohol and quietly take pressure on the ply on a very good male jig, or in a female deck jig (like the Tornado, but this is another technique) and bring it to it's unatural shape. Fasten in order to segragate the bulges, and then come from outside each bulges to the center with the fastening.
You end up with a smooth shape.
I built a lot of little boat like that, it's fun, quick and it looks great.
Compound shape in larger boat can be done repeated the process until the scantling is met. The volatility of the alcohol allow the ply to be glued. The choice of sheathing is not important, everybody has is own soup.
In tortured ply, it is ply involve, the rest is cosmetic.
RWatson, you are not correct. Ply is ply, foam is foam. Richard is right on this one.
Cheers
Daniel
  #35
Old 12-02-2009, 04:43 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1059 Posts: 2,194
Cheers
Daniel
Good grief man - are you still rabbiting on about my harmless comments.
For the sake of you rabid ranters the orginal post - yes the orginal post!!
quote " I thought the market would be inundated with designs for the new method"
So, in the spirit of good natured discussion, I comment on WHY the world is not "inundated" - and I get all this grief about straying off the subject.
We need a few people who think before putting their fingers in gear !!!
  #36
Old 12-02-2009, 09:24 AM
Yes
Just kidding
Cheers
Daniel
  #37
Old 12-10-2009, 07:27 AM
fabrice fabrice is offline
Rep: 10 Posts: 50
Sorry to interfere, I'll just post my newbie and amateur question :
ply is now available "foldable".
One could use it instead of torturing standard ply, couldn't he ?
hum, foldable is not the accurate word : bentable maybe.
Like that : (sorry, french adress)
http://www.bois-et-parquets.com/prod...ntrable,14.php
  #38
Old 12-10-2009, 09:15 AM
aka Terry Haines
Fabrice: flexible plywood is available, it has special laminations and grain directions which make it very easy to bend in one axis, but still stiff in the other direction. It is used for round shapes in furniture and other applications. When 2 layers are glued together it becomes stiff like ordinary plywood.
Babelfish translation:
Fabrice : le contre-plaqué flexible est disponible, il a les stratifications et les directions de grain qui le rendent très facile à faire plié à un axe, mais toujours le stiff spéciaux dans l'autre direction. Il est employé pour des formes rondes dans les meubles et d'autres applications. Quand 2 morceaux sont collées ensemble il devient raide comme le contre-plaqué ordinaire.
Dances with Turkeys
  #39
Old 12-10-2009, 09:22 AM
Rep: 10 Posts: 50
ha ! FLEXIBLE ply
sorry about that !
not always that easy to translate technical datas !
Thanks anyway.
So, you just can't work it both axis at the same time, it's just like the average ply ?
  #40
Old 12-10-2009, 03:30 PM
Rep: 1397 Posts: 7,216
It bends easier in one axis. You could torture bend that plywood too.
  #41
Old 12-10-2009, 06:32 PM
Steve W Steve W is offline
Rep: 315 Posts: 638
I dont think that bending plywood is exterior bonded so check that out before you get too excited.
Steve.
  #42
Old 12-11-2009, 02:38 AM
Rep: 10 Posts: 50
Steve.
hey, stop reading my mind, that was my next question !
  #43
Old 12-11-2009, 01:16 PM
aka Terry Haines
Flexible plywood will bend much more than regular plywood in one axis, it is rather stiffer in the other axis but not much. However the stiffer plies are thicker and will break before regular plywood would.
If I wanted a curve in both directions that regular plywood could not do, I would use strip plank construction, at least on the curved portion of the hull.
Dances with Turkeys
  #44
Old 12-30-2009, 06:04 PM
outside the box outside the box is offline
Rep: 59 Posts: 92
Bendy plywood "A" bond
Hi there all, just thought I would chip in with my two cents worth re Bendi or flexible plywood.
I am building a split moulded Catamaran to my own design here in New Zealand and am using "A" bonded flexi plywood for the core with internal stringers and glass on inner and outer just as one would with a foam core.
Attached are a couple of pictures to show the shape achieved also a picture of an Australian Tri built using same method, benefits are it is very fast to work and nice shape can be achieved.
regards to all Craig
Tortured plywood designs-27122009423.jpg  Tortured plywood designs-03112009278.jpg  Tortured plywood designs-9th-may-2009-2nd.jpg
Tortured plywood designs-9th-may-2009-3rd.jpg  Tortured plywood designs-wl-marina-email.jpg
  #45
Old 12-30-2009, 06:10 PM
Rep: 59 Posts: 92
More of the Auz tri
More photo's of Auz Tri build method.
Tortured plywood designs-port-hull-bow-email.jpg  Tortured plywood designs-cimg2333-port-deck-email.jpg  Tortured plywood designs-cimg2334-stb-deck-email.jpg
Software for tortured ply hull panels? jamez Software 6 02-12-2008 07:01 PM
Newbie here with newbie question. Marine plywood or plywood? photojunky Wooden Boat Building and Restoration 30 07-23-2007 06:41 AM
Tortured Plastic Kayak. alexlebrit Fiberglass and Composite Boat Building 8 05-14-2007 08:41 AM
Tortured Plywood - Design & Construction b_rodwell Boat Design 19 06-18-2006 01:16 AM
Looking for designs ivansalasj Boat Design 3 06-06-2004 03:41 PM
