  #151
Old 10-07-2009, 01:17 AM
aka Terry Haines
Rep: 1682 Posts: 2,818
I get the vet type from my local farmer's store, I'm in a rural location, but the tips on those have the same ID all the way down so cutting off some doesn't speed up the flow. I'll look to see if there is a type that takes a larger needle, though. It's a pity someone doesn't market a double barrel type like the ones the 3 minute epoxy comes in, with the mixing spout that S3 uses on their cartridge system - that would be great.
Dances with Turkeys
  #152
Old 10-07-2009, 06:33 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Mad Scientist
Rep: 1786 Posts: 2,985
There are some cheap plastic turkey basters, if the epoxy flows easily enough.
  #153
Old 10-07-2009, 10:49 PM
aka Terry Haines
I will definitely check out those, should be easier to fill and use, maybe even re-usable too if easy to clean. This is a good time of year ...
Dances with Turkeys
  #154
Old 10-07-2009, 11:19 PM
Rep: 2891 Posts: 8,798
Epoxy just pops right out of these types of plastics.
  #155
Old 10-08-2009, 07:28 AM
hoytedow's Avatar
Mad Scientist
Yeah, just make sure the residual plug(waste)isn't too large.
  #156
Old 10-08-2009, 07:31 PM
aka Terry Haines
Thanks for the info!
Dances with Turkeys
  #157
Old 06-24-2010, 12:38 AM
metal metal is offline
Rep: 10 Posts: 17
Sorry to drag up an old thread. I wish I had found this earlier. I'm building my first boat, a 12 foot flat bottomed dinghy, unfortunately with titebond 3. I fiberglassed the bottom and all the seams, and put plenty of epoxy on there. This little boat is never really going to see rough, choppy seas, it's more of a learning experience and a fun way to blow a few dollars. Should I be worried? I'm not going to cut it up, throw it away, and start over. Is there anything I can do to make sure it stays good and strong? I fiberglassed the bottom and all the seams like I said, and I epoxied the entire outside, sanded it smooth(ish) and used lots of exterior paint. Should I fiberglass/epoxy the seams on the inside as well, maybe add some more bracing to the inside of the boat? The roughest this boat will see is maybe 1-2 foot waves, and it'll alternate between an old 5 horse outboard and a small sail.
  #158
Old 06-24-2010, 02:43 AM
pistnbroke's Avatar
I try
Rep: 372 Posts: 1,230
Having read the reports on titebond 3 it seems you would be best to keep the water away from it ..so yes epoxy and glass tape over any area that could bring the TB 3 into contact with water..you dont say if its stitch and glue or frame construction etc
  #159
Old 06-24-2010, 08:47 AM
apex1
No need to apply glass, that only makes it heavier and more expensive. Neat Epoxy or even several layers of outdoor paint will do the trick!
BUt, Ep does not like to stick on titebond!!!
So, apply three or so layers of outdoor paint (housepaint) on the interior and done!
Regards
Richard
  #160
Old 06-24-2010, 09:25 AM
Rep: 10 Posts: 17
pistnbroke, it's a frame construction (I think). Thanks apex1. I have a gallon and a half of paint for a small boat, I'll keep adding paint until it's all gone haha. That should do the trick. At least it will be on a trailer, covered and secured, most of the time; it will probably only get used about once a month or so, so I imagine it'll last pretty well. Thanks!
  #161
Old 06-24-2010, 09:39 AM
apex1
It will donīt worry................
  #162
Old 06-24-2010, 01:58 PM
Rep: 10 Posts: 17
Sweet. Thanks again!
Murray Peterson Coaster III on Ebay raka Marketplace 5 07-30-2007 11:25 PM
Bluenose III abckits Sailboats 2 09-05-2006 06:41 PM
How to bring a 1961 Evinrude Lark III 40 back to life MarcD Outboards 2 08-04-2006 11:39 PM
Testing Programs McClintockKid Software 4 07-23-2004 12:36 PM
