Old 09-18-2009, 09:38 PM
azzeegator azzeegator is offline
Rep: 10 Posts: 10
Tillamook build
I will be starting my first build in the next few months and would like a little advice from all ya'll experts if ya don't mind.The boat will be the "Tillamook"
one of Jeff Spira's designs.It's a pacific power dory about 16'4" frame on ply
Now my questions are I live in north florida and boat will be used mostly in the Gulf of Mexico with some lake or river fishing occasionally so would live oak be good for frames and chine logs/sheer clamps or would SYP be best?
we have very high humidity down here but boat will be trailored and only used on daily trips also has anyone built one of the Spira boats?
Thanks for any input
Old 09-18-2009, 10:15 PM
alan white's Avatar
Rep: 675 Posts: 2,787
Either wood will do, and white or live oak is superior in terms of strength and fastener-holding, though heavier than SYP. Any trailored boat, if kept drained of rain water, will last well.
Wasn't Tillamook originally a log boat turned schooner that crossed the northern Pacific?
Old 09-18-2009, 10:25 PM
Rep: 10 Posts: 10
I'm not sure of the history of the boats but did find alot of pics on the web of them in use in the northwest www.pbase.com/jeffm/dory2004&page=all thanks
Old 09-19-2009, 12:05 PM
Guest20100203 Guest20100203 is offline
Rep: 0 Posts: 0
I'd use the SYP to save weight and have better rot resistance and less swelling issues then the oak. Save the live oak (my favorite oak) for rub rails and other abuse prone areas.
Old 09-19-2009, 07:15 PM
Rep: 10 Posts: 10
Thanks PAR how should the wood be dried? I believe it should be air not kiln?
how will I know the difference at a lumberyard? It will be fiberglassed
Thanks again for the input!
Old 09-19-2009, 07:48 PM
apex1's Avatar
apex1 apex1 is offline
Steamer
Rep: 898 Posts: 3,631
May I complain here a bit???
It is absolutely inconvenient for the members of this Forum to throw in just a name of a given situation, boat, design, and assuming everyone has to know what we are talking!
You are unpolite!
Provide at least some sufficient data, and / or a picture if you´re talking a state, boat, design, YOU are familiar with!
A link in the second post does not help really!
In this case your neighbours have been happy enough with the given info, but the rest of the forum stays as stupid as before!?!
Regards
Richard
In general you will not notice a difference (the professional world uses kiln dried), the "natural" dried is better though. But, as mentioned, for a amateur building the faults one sums up during building makes the difference between drying methods a laughable issue.
Fortior est qui se quam qui fortissima vincit Moenia.
Old 09-19-2009, 08:05 PM
Rep: 10 Posts: 10
My bad why so serious? these were simple questions on a simple build very basic.The plans are on jeff's website spirainternational
Old 09-20-2009, 04:19 PM
mark775 mark775 is offline
Rep: 479 Posts: 723
I had no idea either and was just about to ask. Here it is; http://www.spirainternational.com/hp_till.html I'd also like the fresh curds, please (Tillamook is dairy country).
Old 09-20-2009, 04:33 PM
Rep: 0 Posts: 0
What are your reasons to build this particular boat Azzeegator?
Old 09-20-2009, 06:17 PM
Rep: 10 Posts: 10
I needed something that will fit in my garage because of HOA also the history of the dory was interesting and it seemed to be within my scope of ability and space for the build.I had a whaler and did extensive repair to delamenated transom and bottom also had soaked foam so boat was heavy.I should be able to take the family out and it should be a good fishing boat for inshore, it can get a little ruff even close in at cedar key
Old 10-04-2009, 08:21 PM
Rep: 10 Posts: 10
still gathering info
I came across this website yachtsurvey.com it has some great general info if anyone is interested I'm trying to get as much info as I can before I start my first boat.The pine should work great for frames,keel,chine/sheers Maybe I'll use some white oak for trim and finish clear that should look great, for fiberglass/epoxy RAKA sounds good to me very good website also I should begin building the jig sometime in november with the real work starting in december I will post some pics then
Old 10-16-2009, 07:14 PM
Rep: 10 Posts: 10
I am wondering about screws to use for the boat I have different opinions about which kind to use I was going to go ahead and get silicon bronze but they are expensive and Jeff Spira which I got my plans from has stated stainless deck screws would be fine on a trailered boat it will be encapsilated in epoxy and I know that some builders even remove all screws just curious if anyone has some insight thanks
Old 10-17-2009, 12:45 AM
boat fan's Avatar
boat fan boat fan is offline
Rep: 277 Posts: 637
If you epoxy glue the whole boat you can use dry wall screws and remove them once the epoxy is set.
Just fill the holes after.
I re - decked a 16 ft daysailer like that . No troubles .
A decent epoxy glue line is stronger than the plywood.
Old 10-17-2009, 05:24 AM
Rep: 10 Posts: 10
I kinda came to that conclusion after researching more it seems that leaving the screws in would be a waste of money and potentially create some problems down the road
Thanks for the input! can't wait to get started just waitin for my bonus! so I can purchase supplies
Old 10-17-2009, 06:36 AM
boat fan's Avatar
Rep: 277 Posts: 637
Yes ! ...I forgot to mention ....screws left in the hull are a good way for water to migrate into the plywood via the threads of fastener. Make sure that the joint is not starved of epoxy ....apply an initial coat to soak in , after that cures , abrade with rough s/paper to key glue to plywood. More epoxy with thickener and your`e good to go .....
If you get stubborn screws that don`t want to come out , ( I had one or two ) you can free them easily by heating the head of the screw with a soldering iron .
Post pics if possible .......Best of luck
First new build StuartRB Wooden Boat Building and Restoration 16 04-15-2009 08:37 AM
first build rlmccook54 Wooden Boat Building and Restoration 8 04-14-2008 08:33 PM
new build thecopperdoc Sailboats 2 12-15-2006 11:11 AM
Where to build?? siolaakis Boatbuilding 6 10-09-2006 03:27 AM
where to build wannabe Open Discussion 5 10-08-2006 08:14 PM
