| strip planking vs aging hello, please look at this link. http://www.gartsideboats.com/faq2.php he doesn't like strip planking. Shortly he says that you can't prevent the wood shriking and expanding, even it is thin strip planked and covered with epoxy. cheers |
| Some O-Jolle built strip planked (It seams it is the German who invented the strip plank) just before the war, in a classical fashion, just edge nailed, still sailing with the hull varnished. I think the more simplier the strip plank is the better. Providing of course you have close space framing. The frames will be spaced twice the space of a normal carvel construction. This is my personal opinion about the spacing, not every body agree. Between the strip, a thick varnish can be used or a type of Bostik 920 but it not mendatory. If you are in hot climat yes a good urethane sealand will be recommended. I don't like the epoxy sheathing. It is not necessary. A normal glue will do, and good ring nails in bronze or galvanized (double dipped hot) For large boat in set of the sheathing I will prefer two oposite diagonal heavy planking veeners on top of the strip glued, and then the last veener longitudinal also glued. I like to have the last diagonal veneer screwed all the way and into the frame. the planking longitudinal veener cover the head of the screws, and will be thourougly glued. It is better to have the longitudinal planking veneer not too wide. A nice varnish will do. But this is my two cents Cheers Daniel Last edited by dskira : 11-30-2009 at 11:27 AM. Reason: I forget a point |
| As he says "Kilndried wood". That's the fault.. 5 years airdrying should do for softwoods. Hardwoods some more.. |
About the aestetic part, in a different part of his website he writes this abou t cold molded boats: "The lack of framing and the flawless finish tend to give cold molded boats a too perfect, 'plastic' finish that often makes them indistinguishable from glass hulls." So when a boat has a nice finish, it is not good, and when it has a more "robust" finish, it is not good either? Quote:
About ABS not recognising wood as a structural material under the waterline: Luckily they did not determine scantlings on older minesweepers... Quote:
Sheathing under the keel is highly dependant on boat design, but if a boat has a "groundable" keel, make sure it is protected well. Whether when traditional built, strip planked, or cold molded, or even polyester or steel. This problem is not specific for strip planked boats. Quote:
My personal opinion is that price of good quality red ceder, which is considered ideal for strip planking, is so expensive now (at least here) that I personally would opt for foam planking. But I cannot condemn others for not sharing that opinion.
| Herman, do you own a Bugatti? Which model? Urisvan you should talk seriously with Richard Apex1, he knows a lot and can guide you better than anybody else. Cheers Daniel |
| I have 2 Bugatti replicas of the "Bugatti Baby" also falsely called "Bugatti type 52" but no large car. Do have a website, though: http://www.bugattibuilder.com
| Strip planking has been around for at least 200 years, that I know of, likely longer. These are all traditional, what was once referred to as "narrow planked" or "set planked". These were edge fastened with and without something in the seams, which was usually shellac, lead or thick varnish. These boats held up well and still do to this day. I'm not sure what Paul's biases are really based in, which are clearly displayed in his "preferred" building methods, but making blanket statements such as he, on strip planked hulls is frankly lacking fore sight and understanding of the method(s). First of all there are at least a dozen different types of strip planking. Do all of them suck or only the ones he has issues with? Are all of them capable of producing too perfect of finishes or can some of them be considered poorly build and faired enough to qualify for his ideas of wooden boat perfection. I guess we shouldn't have glued lapstrake boats either, because they are so difficult to repair too. Please . . . What an arrogant, ill informed ass . . . |
Thank you PAR Cheers Daniel |
| Look just because some may have written books, get lots of column inches in the press and have seen some success, doesn't mean they are right. It just means they managed to tickle the proper butts to get some attention. I do lot of lapstrake repair. Everyone says it's hard to do and it was the first few times I did, but once you get a handle on it, the work isn't that hard. I think repairing cold molded is far more difficult then strip planking, so maybe we shouldn't build out of this method either. Cold molded hulls can be flawlessly finished (I have one) too, so people might think it's a plastic boat and the method should be banned. Come on folks, don't buy into pissed off, ill informed, well covered in the press, old men, that are too set in their ways to adjust to or accept change in their lives or ideals. It's a fact of life. Change is the most essential element of all existence. Without change, the dinosaurs would still be here . . . Apparently, the well regarded Mr. Gartside is one of them. |
An Alternative to Western Red Cedar is KIRI. Well worth a look and lighter than WRC as well |
| But not as strong sabah! Though it is a phantastic material, it cannot replace WRC in every application. Regards Richard |
| If Paul is right, strip planked boats should suffer from broken frames and pushed up decks frequently. Is it common? And what do you think about mahogany for strip planking? cheers Ulas |
Here we use atlantic cedar, it's very good and not expensive. The only downside of strip plank against carvel will be you can allow knots, what ever they are. The strip are too small in section to have knots. I never had a boat with broken frames because pushed against a deck. If the boat is a commercial boat, double sawn the frames and you can push the deck until it goes to the middle of the town. If its a yacht, steam bent will stand hurrican force. As long the frames are close spaced and the structure well designed. The majors bulkead are not enough. Cheers Daniel |
| Urisvan,whether mahogany is suitable for strip planking or not depends on the strip planking method,if it is a traditional edge glued and nailed over conventional framing and epoxy /glass sheathed on a heavier design then yes,we built a 64ft Lidgard design this way 30yrs ago although im somewhat distressed to find out according to the great Paul its probably sitting around with broken frames by now.However,if you are building a strip planked composite boat it is way heavier than you need unless of course you are building a heavy displacement boat by this method. Apex,that kiri is "not as strong"as wrc is somewhat irrelevant in the type of construction that Sabbah uses, its a core and as such it is "stronger" than the common ones such as balsa or foam,maybe wrc is "stronger" but then mahogany is stronger than wrc but innapropriate for this form of construction."Strong" is a term i see used often when comparing different boatbuilding methods and materials and is fairly meaningless,what you need is "strong enough" kiri is strong enough for this method. Im not sure what application you would use wrc for other than the core.. Steve. |
| Steve W has it about right, there are so many different types of strip planking, we need to be talking apples to apples. Comparing a conventional edge nailed stripped hull over steamed frames isn't using the same engineering principles as one build with a cheap, light weight strip core that has heavy sheaths on both sides and no internal frames. In most cases currently, people are using strip planking as a cored build (sandwich or composite), not a "narrow plank" build. In this regard, you can use pretty much anything you want for the strips, foam, cheap wood, cardboard, mashed potatoes, etc., so long as the peel and compression strengths meet minimum requirements at keeping the two skins in proper orientation to each other. Okay, maybe mashed potatoes wouldn't have the compressive qualities necessary for the job, but if my aunt Rita's recipe was used, they'd easily have the peel strength when dry. |
| Speed Strip tongue-and-groove strip planking | Jeff | Materials | 38 | 08-04-2009 11:12 PM |
| Repairing Strip Planking | Brands01 | Wooden Boat Building and Restoration | 5 | 03-07-2007 12:34 AM |
| Strip planking vs wide planking | jfblouin | Wooden Boat Building and Restoration | 26 | 08-11-2005 09:00 PM |
| Fasteners in strip planking | jfblouin | Wooden Boat Building and Restoration | 5 | 03-04-2005 06:14 PM |
| Books - strip planking | mojounwin | Fiberglass and Composite Boat Building | 1 | 01-06-2005 03:04 PM |
