Old 10-17-2010, 11:16 AM
wardd wardd is offline
Rep: 443 Posts: 925
strip planking v ply
a couple questions
can strip planking be done cheaper and of the same quality as ply?
can a design for ply be strip planked without major changes other than subbing strip for ply?
will it require more frames?
liberty ships were beautiful
Old 10-17-2010, 11:26 AM
TeddyDiver's Avatar
TeddyDiver TeddyDiver is online now
Gollywobbler
Rep: 1348 Posts: 2,057
Yes and no to all above..
I'm afraid you got to be more specific if you wan't more accurate answers..
Old 10-17-2010, 11:34 AM
Rep: 443 Posts: 925
with comparable boats can strip be of just as high a quality and cheaper as marine ply isn't used?
how would the structure differ between ply and strip, other than the hull plating?
this would be at or under 40' x 8.5'
it's a displacement hull and speeds
Old 10-17-2010, 11:38 AM
TeddyDiver's Avatar
Gollywobbler
Yes it can
Many ways bcs there's many different methods for both of them
At that size defineatly strip planked IMHO
Old 10-17-2010, 11:39 AM
Rep: 443 Posts: 925
you're saying you prefer strip plank at that size?
Old 10-17-2010, 11:40 AM
Rep: 443 Posts: 925
does strip planking require closer framing?
Old 10-17-2010, 11:46 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1874 Posts: 3,359
Yes, because you lose the benefit of the bracing provided by internal cross grain transversely extending across the hull.
Hoyt
Old 10-17-2010, 11:54 AM
Rep: 443 Posts: 925
Originally Posted by hoytedow View Post
Yes, because you lose the benefit of the bracing provided internal cross grain transversely extending across the hull.
see, you can say things i can agree with
would being epoxied make up for some of that?
Old 10-17-2010, 12:00 PM
TeddyDiver's Avatar
Gollywobbler
And not at all if you use the internal stucture to carry the transversal loads.
Old 10-17-2010, 12:03 PM
hoytedow's Avatar
Resistor
Yes. Epoxy would add strength. To what extent? That is a matter of skill.
Hoyt
Rep: 443 Posts: 925
I'm thinking bead and cove over frame waterproof glue with glass epoxy covering
what kind of glue and other thoughts?
Old 10-17-2010, 12:12 PM
hoytedow's Avatar
Resistor
Of course, you are right. But lacking that it would be weaker.
Hoyt
Old 10-17-2010, 12:18 PM
TeddyDiver's Avatar
Gollywobbler
That's better with smaller boats, boats treated with conventional impregs and glues, not worth a though if you were to use epoxy with glass..
It's a very broad subject, and there's no single right answer. You need some reading like Meade Gougeon: The Gougeon brothers of boat construction..
Old 10-17-2010, 12:21 PM
Rep: 443 Posts: 925
can you elaborate?
Old 10-17-2010, 12:29 PM
TeddyDiver's Avatar
Gollywobbler
It's a more complicated matter. Think of every bulkhead, cabinetry and shelves as a part of internal framing. Everything is arrangenge so that the "panel size" around the boat is in right proportions and sufficient to support the hull skin. In this so called "monocoque" structure it's all glued and bonded together, covered with directional fibers and epoxied together. No screws or nails needed. Anyway it's a good structure and no more vulnerable compared to any framed boat which can also be just as good as the engineering behind it..
strip planking vs aging urisvan Wooden Boat Building and Restoration 16 12-06-2009 04:54 PM
Speed Strip tongue-and-groove strip planking Jeff Materials 38 08-04-2009 11:12 PM
Strip planking vs wide planking jfblouin Wooden Boat Building and Restoration 26 08-11-2005 09:00 PM
plywood vs strip planking jfblouin Materials 2 03-08-2005 02:55 PM
Fasteners in strip planking jfblouin Wooden Boat Building and Restoration 5 03-04-2005 06:14 PM
