| strip planking instead of lapstrake Just a quick question, Does anyone know if I can simply change my boat plans from lapstrake planking to strip planking. Has anyone had any experience in either of the two construction planking methods. I am more preferential to the sleek smooth finish of the strip planked hull instead of the lapstrake as I will be finishing my hull clear coat mahogonay or similiar. Cheers everyone |
| If your boat is more or less a dinghy size no worries. With bigger projects there might come some issues.. |
| Well my boat that I am constructing is a 19.3 foot power boat with 2 berths sink toilet etc. What sort of problems would I have? Cheers |
| A strip planked boat is usually a fair amount heavier then a lapped boat, particularly if a glued lap build. Yes, you can change to lap, from a strip build, but you'll have to adjust scantlings to suit, which isn't a simple task and likely not within the realm of the novice. I'd have to spend several hours working out a new schedule and it wouldn't be my first picnic in this regard. The novice would have to be very well versed with construction methods and scantling arrangements for the two methods. For what it's worth, there's not much better looking a hull then a lapstrake, especially if finished bright. It is a much less novice friendly method then strip planking, but a very rewarding result. You'd be best advised to consult a designer for a proper set of scantling conversions. |
| You might consider doing the calcs yourself after studying The Elements of Boat Strength by Dave Gerr or another good book having usable scantling rules. |
| Dave Geer's book is a fine bit of work, but he is assuming much about the reader's previous skills in design and engineering boat like structures. If you understand building principles and common engineering ploys to solve potential issues, then it's an enjoyable book. If you're relatively inexperienced in this, it can be a "thick" read, in spite of Dave's writing style. |
| Thanks for all the info guys |
| Speed Strip tongue-and-groove strip planking | Jeff | Materials | 38 | 08-05-2009 12:12 AM |
| Lapstrake or carvel planking for small home-made? | rstevens | Boat Design | 3 | 01-31-2007 08:24 PM |
| Strip planking vs wide planking | jfblouin | Wooden Boat Building and Restoration | 26 | 08-11-2005 10:00 PM |
| Fasteners in strip planking | jfblouin | Wooden Boat Building and Restoration | 5 | 03-04-2005 07:14 PM |
| Books - strip planking | mojounwin | Fiberglass and Composite Boat Building | 1 | 01-06-2005 04:04 PM |
