Old 04-26-2010, 01:08 AM
tangent40 tangent40 is offline
tangent40
strip planked decks
I am currently installing kaya planking on the decks of a 38' connie. The existing ply decks are coated with a heavy mill "rubberized" coating that is near inpossable to remove. My plan was to bed the new planking in a polyurathene addhesive/sealant and fasten from the underside as to create a good bond/flex barier from the existing decks. Is this a bad idea as it will be my first planking job?
thanks,
TANGENT40
Old 04-26-2010, 01:40 AM
Lurvio's Avatar
Lurvio Lurvio is offline
Mad scientist
Rep: 219 Posts: 267
I'd say do a test, glue a piece of strip on the deck (somewhere less visible) and when the glue is dry, remove the strip. You'll see how it sticks. How thick the strips?
Hopefully creating something useful, since 1983.
Old 04-26-2010, 12:47 PM
Rep: 1493 Posts: 7,447
How thick are you planking with that you can screw from the underside? Usually, layed over decks are 3/8" or so.
Old 04-26-2010, 01:49 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
If the original decks are sound, any screw fasteners from above are an invitation to water getting into what is now a perfectly good core.
Screwing from underneath is chancy--- either too little bury or a chance of going through (now or later as the deck is refinished).
Going with adhesive alone may be the answer (thickened epoxy). The problem then becomes holding the boards in place until the epoxy sets.
Setting up a system to hold down the planks isn't too difficult, though it might have to be done over a longer period of time, in stages.
I'd not send screws through a core unjacketed if I could help it, and yet all it takes is a single leak to cause a lot of misery.
Think about no fasteners.
Strip planked boats and saildrives? Omeron Sailboats 5 05-06-2008 11:18 AM
Strip Planked hull restoration Wilt Sailboats 5 09-25-2007 11:31 PM
strip-planked hulls Puzzled Wooden Boat Building and Restoration 15 11-16-2006 08:46 PM
A sand bagger - strip-planked DanishBagger Fiberglass and Composite Boat Building 28 02-21-2006 03:08 AM
Strip Planked Daggerboard nero Wooden Boat Building and Restoration 0 06-30-2005 10:31 AM
