Old 08-29-2009, 12:09 PM
steveroo steveroo is offline
Rep: 10 Posts: 38
The Stove
I got this beautiful old 1955 Monk a 36 footer, and the stove on board has been there since Neptune knows when. The remnant bit of instructions on it say to turn a valve on below decks to open a diesel line, and then to flip a toggle to allow 5-6 gallons to flow to the stove reservoir. Well that's all i know about it. I've never fired it up, and I'm rather anxiuos to give it a try. The controls say "Singer" but other than that I have ZERO information. I am enclosing a few pix in case someone has actually operated this kind of unit previously, and in the hopes that it can be identified as to make.I have tried to find out more info online, but it's terribly tedious, and I was hoping one of the old salts might recognize this little beauty. Any help would be totally appreciated. There is also an external filler aperture for this unit, but I have yet to uncork it and check for fuel assuming that once I open the fuel valve and toggle the pump, the diesel will actually go to the unit. Any Ideas???
Old 08-29-2009, 01:24 PM
mark775
It has been a long time but I think it is a Dickinson, probably the "Pacific" model. Is the top 22" across? Anyway, just get ahold of them in BC:
Tel: 1-800-659-9768 (toll free)
Email: info@dickinsonmarine.com
Tech Support: tech@dickinsonmarine.com
You need to have good ventilation, a secure exhaust, get all old soot/corrosion out, and 5 or six gallons seems like a lot of fuel. Start at the source (the fuel) and make sure it is reasonably clean, runs through a filter, and is completely dry. Make sure that the stove pipe is completely obstruction-free and stout and the fan is working, if one. The burn chamber is that thing on top and remember that if things go haywire, simply close the lid and shut off the fuel. Consider taking that stovetop outside and sanding it to get it back, then see a restaurant supply for a griddle cleaner and always make your polishing marks (every day of use a few strokes) run the same direction to look nice. Slap those who would pour coffee over the now gleeming, toasty, cozy stove.
Old 08-29-2009, 01:25 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2006 Posts: 1,639
Steve,
It's a typical West Coast boat stove, built by many small firms along the coast, Washington Stove Works, Olympic Stoves, etc, Dickinson is almost the only one left now http://www.dickinsonmarine.com/ You can find user manuals on their website. But you have the old style carburetor and all Dickenson's now use a newer one.
The stove burns diesel oil, and they were built in the days when consumption was not a concern. They were often left on (low setting) year round. The problem with starting and stopping these is that they take forever to get hot from stone cold. You need to think well ahead (like hours) if you want to cook something. Forget flashing her up to boil a kettle....it ain't happening. Usually folks also carried a colman white gas pressure stove for those situations in summer.
Usually these stoves were fed oil from a small gravity tank on the roof. This tank was often filled via a hand pump from the main tanks, or with the overflow (return line) from the main engine. Sometimes there was no day gravity tank and they use a tiny 12V impulse fuel pump plumbed directly from the main fuel tank to the carburetor.
There's probably (should be) a fuel line shutoff valve somewhere between the tank and the carb. Turn that on. Then you need three things, a flashlight, a bit of toilet paper, and a match. Turn that carb control all the way to start, lift the lid and look in the burner with the flashlight to see if it gets wet in the bottom. When it's wet, light your paper and drop it in the bottom of the burner. Once the oil catches, close the lid and turn on the blower (push-pull switch under the carb). There's a oven damper knob over the oven door on the front of this stove. Pull that out before lighting, push it in once she's going which will circulate heat around the oven.
Keep an eye on it, don't let the top get red hot or she'll warp. Turn it down as she warms up, you'll get the hang of it quickly. Never trust this stove, a bit of dirt can jamb the carb float and flood the stove. This usually results in the boat burning up, it used to happen all the time.
Old 08-29-2009, 01:41 PM
mark775
I don't like the gravity feed for the reason stated (fire). Don't trust any fire on your boat but don't be afraid of this thing - it will keep you warm if you take care of it. I feel a need to emphasize the "cleaning/checking" and that you don't just fire it up if fuel gets there.
Old 08-29-2009, 05:52 PM
thudpucker's Avatar
thudpucker thudpucker is offline
Rep: 330 Posts: 703
It now only keeps you warm, but there is no heat like that Diesel stove for drying out a cold wet cremember.
As mentioned it ran continous in the winter and chilly months and Rainy seasons.
You had to let some oil get into the Chamber, then drop a flaming news paper or such down on the oil. Some guys put the wadded up paper in and let it soak, but that always caused a bunch of black smoke.
I believe it helped to keep the moisture out of the boat too.
Old 08-29-2009, 06:55 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Good advice.....
Old 08-29-2009, 08:52 PM
Rep: 10 Posts: 38
The Stove (con't)
Thank you gents for your words of wisdom. I DO utilize a little 2 burner propane Coleman for coffee and quick meals.The pipe and it's connections are all good. and TRUST Me, it will look as near new as possible, and probably more thoroughly cleaned than she has ever been long before I put a flame to her. I had also heard that these stoves were in high regard when kept properly maintained, and that indeed, many were left on continuously to have a warm spot, to keep the humidity down, and to be ready at a moments notice to heat up some chowder for the crew.Much obliged for the starting info, and again be reassured that I will take every precaution including a handy extinguisher on initial fire up. The stove is flashed below, on both sides, and up the cabin wall as well, so someone was thinking right when it was originally installed. When all is right with this valuable piece of equipment I'll post pix and the procedures I used to get it running, for archive's sake if nothing else. On to my next post ...about paint
Old 08-29-2009, 09:39 PM
thudpucker's Avatar
Rep: 330 Posts: 703
You'll make little Copper wire 'hooks' to hold the Coffee pot and some other stuff in place if you are heating near a wake zone or out on the river somewhere.
Dickinson Oil Stove TollyWally Marketplace 1 12-25-2007 10:30 PM
Taylor Kerosene Stove ORION1 Sailboats 6 08-29-2005 05:53 PM
