Old 07-19-2007, 08:48 AM
msbealo msbealo is offline
Rep: 10 Posts: 4
Stitch and Glue build size
Hello,
This is my first post, but I was hoping to get some opinions.
I've been looking into constructing my first Yacht. I've rather drawn towards the stitch and glue method but have a couple of questions.
1) I've found a few plans on-line, notably the Vagabond 26. I've also seen a number of other boat plan sites. What is the largest Stitch and Glue sloop rigged yacht that has been made/planned? Do they come in over 30'?
2) What are the construction costs for a Plywood, stitch and glue sailing yacht in the region of 30'? How is this broken down into Hull construction, sails, Mast, sailing gear and other?
3) What size boats does Samual Devlin's Stitch and Glue book cover? Anything up to 30' size?
I hope some people have some experience with building larger S & G boats.
Regards,
Old 07-19-2007, 06:59 PM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Tape and glue may be useful for larger boats, but are you sure you don't want to raise the frames and bulkheads first (and build some of the interior), then add some stringers and then have something to fasten the skin panels to?
Here is my estimate:
1/3 of the displacement may be cargo, crew etc.
1/3 may be "the boat"
1/3 may be ballast, probably less in modern designs.
So, if your 30 footer have a displacement of three tons, you need one ton of wood and epoxy. This is a rude estimate, of course.
Take a look at the material list for Didi 26 for example,
http://dixdesign.com/did26mat.htm
My estimate of the plywood sheets listed is 500kg.
The finished hull is approx 400kg, then you have 400kg of lead, lightweight displacement is one ton and loaded one and a half (1500kg).
My estimate for the Didi 26 is
10.000 Euros for the complete hull and interior, plywood, epoxy, lead for the bulb and aluminium profiles for keel and rudder.
5.000 for a complete rig with standing and running rigging, ready made, double that for carbon.
5.000 for all hardware on deck, hatches, stanchions etc,
5.000 for new sails, more for raising sails, much less for second hand sails.
If you want a cheap boat, find a second hand rig first, then buy some second hand sails and gear, then build a boat to match :-)
Materials may cost 10 Euros per kg, plywood a little less, epoxy and glass a little more. It depends on your sources and the quantity, of course.
Since you are in UK, check out Robbins Timber in Bristol.
A crude estimate for building time is one kg per hour :-)
If you want to try something smaller first, here are two boats I like,
http://www.mboats.no/B18/Brochure%20English.pdf (strip planed bottom, plywood topsides)
http://www.geocities.com/cdbeckwith/iBoat/i550.html (stitch and glue)
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 07-19-2007, 07:02 PM
Raggi_Thor's Avatar
And sorry I didn't say HI and Welcome to this forum!
You will get a lot of good advice here
www.MBOATS.no
Old 07-26-2007, 10:18 AM
Gilbert Gilbert is offline
Rep: 28 Posts: 511
Take a look at devlinboat.com
Old 07-27-2007, 09:37 AM
boatbuilder.org boatbuilder.org is offline
Rep: 10 Posts: 54
Devlin's largest sailboat is the Means of Grace http://www.devlinboat.com/dchogmog.htm and the largest powerboat is the Sockeye 45 http://www.devlinboat.com/dcsockeye45.htm . We can build bigger no problem but have not found a buyer so construction plans for larger designs have not been generated. The largest sloop that plans are available for is the Sooty Tern http://www.devlinboat.com/dcsootytern.htm
---Joel---
Stitch and glue restoration zoso Wooden Boat Building and Restoration 9 07-11-2006 06:23 AM
Stitch-n-glue or Strip? Neverbehind Wooden Boat Building and Restoration 13 04-21-2006 10:06 AM
stitch an glue boat size.. hob_n Boatbuilding 9 09-23-2005 11:03 AM
26' stitch and glue regal Boat Design 5 07-09-2004 01:10 PM
stitch and glue Boatbuilding 2 06-27-2002 09:33 PM
