Old 04-25-2010, 03:26 PM
chuckboat chuckboat is offline
Mr. Ishman
Rep: 10 Posts: 6
Standards for hull thickness
Can anyone tell me if there is a standard practice for determining the hull thickness for a wooden boat?
I am drafting plans to build a 20x8x4 foot wood boat. It's intended purpose is for low speed pleasure cruising, so high stress points should not be a concern. I am considering a 1/4'' hull thickness, ply wood over a wood frame, stain and varnish inside and out.
All comments welcome.
Chuck
Old 04-25-2010, 04:16 PM
rasorinc rasorinc is offline
Rep: 687 Posts: 1,175
I like a minimum of 3/8 to 1/2" bottoms and lean toward 1/2" for a 20' length.
If you have curves go double 1/4"--hard to bend 1/2". If your going to be boating in a stream or river with lots of rocks go 5/8"
Old 04-26-2010, 01:38 AM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1625 Posts: 1,170
see if you can lay your hands on Gerr's book "Elements of Boat Strength" It is all there and more.
Wynand
A scatterling of Africa
Old 04-26-2010, 02:45 AM
Boston's Avatar
Boston Boston is offline
Rep: 1457 Posts: 3,357
its also in elements of yacht design by Skene
20' boat eh
plank thickness of 7/8 is what old Skene lists for a simple plank on frame keel wooden power boat
at 1/4 inch you might want to bring some swim gear and a few extra towels
I am skeptical of the deniers diatribe
Old 04-26-2010, 07:31 AM
conceptia's Avatar
conceptia conceptia is offline
Naval Architect
Rep: 97 Posts: 193
Elements of Boat Strength is a good one to start with...
Cheers
Aswin
"Aim of any argument or discussion must not be victory, but progress."
Old 04-26-2010, 09:23 AM
Mr. Ishman
Rep: 10 Posts: 6
RASORINC: Thanks for the advice. I'll go with 2 layers of 1/4 ply for hull.
WYNAND N: I'll add Gerr's book to my set.
BOSTON: I think we will have plenty of towels and buckets on hand on our maiden voyage. Will post performance results when I have them.
CONCEPTIA: Thanks for your additional reconendation for Elements of Boat Strength.
Fiber configuration in lamination of hull thickness amamini Fiberglass and Composite Boat Building 4 04-20-2010 11:42 PM
Fiberglass hull thickness AndamanSS Boat Design 4 12-24-2007 10:44 AM
Hull thickness for 16 foot skiff willfishforbeer Fiberglass and Composite Boat Building 10 03-18-2007 08:46 AM
FRP hull thickness tdamico Boat Design 19 09-14-2004 08:20 AM
How to calculate the thickness of a hull? jb Boatbuilding 3 11-07-2003 09:12 PM
