Old 03-30-2006, 08:52 AM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,842
SS and Pit Corrosion
Does anyone know if 304 SS suffers from Pit corrosion in fresh water?
Steve
Old 03-30-2006, 10:08 PM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,580
Hi Steve,
304 is also known as 18-8 because it has approximately 18% chromium and 8% nickel. It will corrode under harsh conditions but is used commonly in marine environments.
Edited to add I don’t think it is recommended to use 304 screws in wooden boats below the water line, I would use Monel.
Gary
"The hand feeds the mind."
Weston Farmer
Old 03-31-2006, 05:10 AM
DanishBagger's Avatar
DanishBagger DanishBagger is offline
Never Again
Rep: 523 Posts: 1,543
Couldn't one just upgrade to 316? I mean, instead of going monel (=$$)?
Old 03-31-2006, 05:17 AM
dimitarp dimitarp is offline
Rep: 19 Posts: 89
The 316 is better than 304, but monel is better than 316
Old 03-31-2006, 05:20 AM
Never Again
True, but isn't much more expensive?
The reason I'm trying to make that point is that if money weren't an object, the thread starter propably wouldn't have asked if he could use 304. Or, at least that's how I read it - it wouldn't be the first time I was wrong.
Of course,he could also use silicon bronze, or titanium
(wishing I could afford titanium myself)
Old 03-31-2006, 05:24 AM
Rep: 19 Posts: 89
I think that the price of 316 i not defferent from 304. But titanium is more expensive
Old 03-31-2006, 05:32 AM
Never Again
Lewis,
I found this link:
http://www.assda.asn.au/asp/index.as...34299&id=56951
The thing is, it seems to be able to hold up, but the moment you introduce electricity (from a stray wire, for instance) things begin to happen, as I understand it. Crevise corrosion is one of my real fears about this.
Caveat: Please dotakethis with a grain of salt, I'm certainly not very experienced in boatbuilding, nor have I owned tons of boats. However, my boat will be built with bronze screws below the water line, bronze screws in the gunwhale and so forth. Onlyin places where I either cannot get bronze for the application, or where it is _very_ easy to exchange will I have stainless steel. Hell, my padeyes will be titanium.
Is it a trailer sailer? Wood-epoxy? "straight" wood?
I mean, if it's a trailer sailer, and all the fasteners are made the way the gougeon brothers do it (the screws are inserted into a plug of epoxy), I can't see any problems arising.
On the other hand, trailing a boat on the road, getting road salts up there, suddenly you will have a saltwater environment.
Anyways, if I were you, I would use the best you can afford, when it comes to fasteners below the waterline. Skimp on something easily changed instead.
Old 03-31-2006, 08:03 AM
lewisboats's Avatar
Obsessed Member
The main fact is that I can 3/4" by what ever length I want of 304 bolts and nylock nuts for free...very much an incentive to use them. I would be using them on a small (11.5 ft) Stitch and Glue sailboat with a simple plate steel keel (maybe also 304 SS) with a jack knife style dropdown swinging section. The keel will be mounted to a wood fairing pad with the bolts welded on top and thru bolted to floor timbers. The only electrics would be battery powered, closed loop stuff, no common ground.
Steve
Old 03-31-2006, 08:17 AM
lewisboats's Avatar
Obsessed Member
Originally Posted by DanishBagger
The way I read it...I should be in the clear. This all relates to salt water, it even says you should rinse your 304 off with fresh. Guess I'll be rinsing it off with every outing. In fact...cleaning my stainless might become an obsession
Steve
Old 03-31-2006, 11:02 AM
Never Again
Indeed, that's how I read it as well, Lewis.
About the electricity, I was talking about other's, but seeing how small it is, I assume it would get out of any water fairly often.
Good luck with it
Old 03-31-2006, 06:12 PM
Rep: 1729 Posts: 2,464
Steve
If it is in wet wood fresh water or otherwise, yes it will pit and crevice corrode.
Mike Johns.
Cock Pit Drainage Allan Jennings Metal Boat Building 3 01-13-2006 05:49 AM
Void space corrosion inhibitor sailrjim Metal Boat Building 5 12-20-2005 06:57 AM
Fixing lead filled sheet metal keel with internal corrosion DennisRB Sailboats 2 08-02-2005 02:01 AM
Corrosion between Al and carbon grob Materials 11 02-18-2005 11:39 AM
Carbon and corrosion Ssharpsjc Materials 5 07-08-2003 08:24 AM
