  #46
Old 08-13-2011, 03:58 PM
txriverrat txriverrat is offline
Rep: 122 Posts: 142
This boat has turned out well for me , and like I said at the beginning of this build it was taken from a boat designed and Paddled by Verlan Kruger. I preforms well.
I dont really know what to call this boat , a kayak , decked canoe, I guess it is a hybrid of both.I build boats because they are lighter ,I can customize them to my desired uses, and most of the time they paddle a lot more efficently than the plastic boats.
I dont knock the plastic boats ,they got a lot of folks involved in yaking and paddling,so I guess that is good. There is a lot of hype ,bs, about designs and some just flat out lies about there performance from folks chasing the dollar.
Thanks for the thumbs up
Ron
  #47
Old 12-19-2011, 02:47 PM
Rep: 122 Posts: 142
I am doing this a little different than most boat reviews. I decided I was going to put some miles on the North Wind and paddle in as many different environments as possible before I wrote this up,so here we go.
This boat is 17 ft 2 inches long bye 28 ½ wide finished weight was 54 lbs ,not a little boat by any stretch of the imagination
When I built the deck I set it up for a 58 qt cooler ad the capability to carry 8 rods all that worked out well
And the places for the rod holders are also used when I just pull up and want to bank fish or troll.
She has been slimed
Been paddled tandem
Loaded heavy
Stability is awesome ,my seat is 11 1;2 inches high and I never feel tippy.
Paddling speed is awesome ,if your paddling beside most yaks you have to back off a lot because just paddling at a normal cadence you will walk off and leave them.
Comfort and weight carry capabilities are great ,as you add weight she just doesn’t notice it at all and the 7 ft cockpit is easy in and out, two 5 ft enclosed decks carry a lot of gear. A note here she does like to be loaded tail heavy.
This last weekend we paddled 14 miles loaded 7 up and 7 downriver,shallows ,deep holes , going through blow downs with a lot of current .she just handles it all in stride , the hull is slick enough to paddle upriver better than any boat I own.
I have to rate this boat head and shoulders above any boat I have ever paddled . I guess that says it all.
Ron
  #48
Old 12-20-2011, 07:46 PM
cthippo's Avatar
cthippo cthippo is offline
Rep: 452 Posts: 725
Awesome TX, nice work!
I would call it a kayak since it's designed to be paddled from the middle rather than the ends, but that's just my working definition.
A 'yak without a cockpit ring still seems horribly, horribly wrong, but I'm slowly getting acclimated to the iead from yours and LPs work.
Aluminum welding is like sex. The first few times you had at it, you probably could barely please yourself, but with practice and some guidance, you managed to impress one or two prom dates. ~PAR
