Old 10-24-2006, 10:04 PM
Broach Maharg Broach Maharg is offline
Rep: 10 Posts: 2
Spreader Light's wiring on wooden mast?
I will be installing lights up my wooden mast. I'm looking for suggestions for running the electrical. Up shrouds? Oh, antennae too.
Old 10-25-2006, 12:49 AM
Rep: 3125 Posts: 9,408
On solid sticks, there's only a couple of neat ways to do this. First don't run them up a shroud, it's a pretty lubberly thing to see. The most common method is to staple it, with insulated staples, in a handy location, that will not foul anything (tracks, pole sockets, etc.). Another method is to route out a shallow groove, deep enough to accept the wires and a filler, which is tacked in place over the wires. This method doesn't noticably weaken a solid mast, unless it's just adequate for it's role (read, all out racer). I've seen a few who have epoxied in the filler piece over the wires, making the stick whole again, but the wires become a life long fixture of the spar, without major digging to retrieve a broken wire, later in it's life.
On hollow poles you have a few options. The common method is to fish it up through the inside of the mast. This can require some surgery to accomplish the task, particularly if you have hard points (swallow tails) spaced along the length of the mast. These have a weep hole to permit moisture to drain out, but often times it isn't big enough to pass the wires through. On sticks with internal halyards, this space issue may not be an problem, though tangles and chaff can become a problem without a "chase".
A halyard can be used to pull a "fish" through, then the fish can be attached to the wires and the halyard (so you can re-reeve it) and pulled through.
You should already have a masthead light, how is it attached? If the hollow stick doesn't have the space inside to pass the wires, it's attached on the outside, just like a solid pole.
Cutting a groove in a hollow spar isn't a good idea. I don't like the thought of cutting into stave thickness, even if it gets back filled with epoxy, but I have seen a few that have done just that.
What kind of mast is it? Antenna type? Gauge of wires for lights? Internal halyards?
Old 11-07-2006, 07:42 PM
Rep: 10 Posts: 2
Thanks for your suggestions.
There is no masthead light on this mast. It is a solid spruce mast on a fiberglass boat from the early 1960's. There are only red and green lights on the salon walls.
I think I've decided to tack the wires so as not to compromise the strength of the mast at all. Does it make sense to cover the wires with a piece of trim - say mahogany? I've also decided to not install an antennae on the mast. I do still plan on spreader lights and either a masthead or half-way up running light and keeping the starboard and port lights on the salon.
Again, thanks. No lubberly look here...
Old 11-08-2006, 06:42 AM
On a solid spar, you can route out a groove, which can be covered with a thin piece of spruce, for a hard to see look, without compromising it's strength. Tacking them on is acceptable too. I've never seen a cap used on surface mounted wires, but would think it could work. Be careful not to trap moisture behind this cap, which may cause trouble later.
wooden mast wanaco Materials 8 07-05-2008 11:34 AM
Wooden Mast Construction wonderlost Wooden Boat Building and Restoration 7 06-18-2006 03:43 PM
Laminated wooden mast Audun Materials 5 05-22-2006 02:32 AM
Re-glueing wooden mast Aurora Wooden Boat Building and Restoration 18 04-20-2005 08:04 PM
bent wooden mast Simon Monard Sailboats 5 03-10-2005 03:08 PM
