Old 10-28-2011, 06:39 PM
cthippo's Avatar
cthippo cthippo is offline
Rep: 452 Posts: 725
So what would happen if...
So what would happen if you took a traditional plank on frame wooden boat, stripped off the (old, rotten) planks, rehabilitated the frames as needed, and then built a cold molded hull over the frames? Granted, it would probably be heavier, but the durability and reduced maintenance might make it worthwhile.
Thoughts?
Aluminum welding is like sex. The first few times you had at it, you probably could barely please yourself, but with practice and some guidance, you managed to impress one or two prom dates. ~PAR
Old 10-28-2011, 07:16 PM
Rep: 3125 Posts: 9,408
If you took a carvel, restored it's structural frame work, then replaced the planking with a mold hull shell, you have a lot more structural frame work then necessary for that new hull shell. Worst off, the frame spacing for the carvel may not be close enough for the first layer of molded material, so it would sag, making for a nightmare planking situation. It would also be much more costly then just replacing the carvel planks, which is about the easiest of all the planking methods to replace. Yep, the molded hull shell wouldn't have to be regularly caulked, but there are other considerations.
what do you think would happen if... Frosty Boat Design 8 10-22-2011 08:27 AM
What would happen to this floating platform in a Tsunami? Dr.Smart Open Discussion: All Things Boats & Boating 14 03-17-2011 05:34 PM
What happen to regular fiberglass on water? Shafri Materials 73 02-02-2011 09:47 PM
what will happen when a hurricane hits Gulf spill? Squidly-Diddly Open Discussion: All Things Boats & Boating 217 07-12-2010 06:24 PM
Olympic Sailing Course - How does this sort of thing happen? Capn Mud Sailboats 11 06-26-2008 11:14 PM
