| skin on frame transparent materials So i have the plans for a whitehall 15 from geodesic aerolite boats, though was wondering about transparent materials. I emailed them and bette told me that platt did a mylar skin. She did not recall the mils. I'd probably do an epoxy topcoat... Any recommendations on thickness, and thermoforming? I've seen rolls available up to 10mils. Thanks! |
| According to the website at gaboats it was done with clear Monocote, a film used by R/C model plane hobbiests. I used the material many times on R/C planes. I do not recall the thickness, but amazingly durable, considering. They have a link to the information on the site. You should be able to determine the mils of the product from the vendors website.
__________________ Darr Palmer SmallYachts www.smallyachts.com "Crewed by sailors, adventurers and friends" |
| The Monocote is the brand name for a shrinkable mylar. Mylar is tough but it is easy to puncture, so using it is a just a fun temporary skin at best even in the thickest materal you can find. You can also use the clear vinyl with polyester reinforcing filaments you see used on the clear sails used on sailboards or performance racing dingys. It would hold up better than mylar, but will eventually yellow and get abraded were it contacts beach, dock and trailer. Polyester fabric sealed with a clear finish will be translucent but not clear. I have built a number of skin-on-frame boats with both fabric and plastic skins, including clear plastic. You can not see as much through the bottom of the boat as you might imagine, even in clear water, so I would suggest you try it with some inexpensive plastic wrap to see if it accomplishes what you want where you normally sail. Good luck. |
| Fascinating. A place around me carries polyester up to 7mils, the can get up to 10.. Were you thermoforming it to make.it taught? I would be coating it with polyurethane or clear epoxy. Also a UV barrier. |
| I know a guy out in Acme who builds very traditional boats and used nylon for the skins. They come out pretty translucent when finished, and pretty indestructible. http://www.dwkayaks.com/index.html Something I've considered, but not actually tried is heavy gauge clear vinyl like they use to cover table tops. Any sewing store should have it and it's pretty tough stuff. If you do try it' let me know how it works! Last edited by cthippo : 10-09-2010 at 11:56 PM. Reason: all that and I forgot to put in the URL! |
| Skin on Frame Raft | djwkd | Wooden Boat Building and Restoration | 10 | 03-25-2010 04:52 PM |
| Skin-On-Frame + Power | rgardn12 | Boat Design | 9 | 03-17-2010 10:50 AM |
| skin on frame canoe outrigger | fabrice | Wooden Boat Building and Restoration | 2 | 08-01-2009 02:18 AM |
| Fabric skin over frame construction | sailsocal | Boat Design | 4 | 02-24-2009 06:13 PM |
| Expedition - skin on frame kayak for sale | dirtybeard | Marketplace | 0 | 06-12-2007 09:48 AM |
