Old 07-31-2009, 10:00 AM
fabrice fabrice is offline
Rep: 10 Posts: 50
skin on frame canoe outrigger
Hi everyone,
I'd like to have your point of view on this :
I REALLY enjoyed paddling a 6 men va'a, and would like to build a skin on frame version downsized to 2 paddlers.
Don't know exactly where to begin ...
silly idea maybe, but capefalcon sailing outrigger gave me some dreams to follow - their fault, not mine
Old 07-31-2009, 11:38 AM
alan white's Avatar
Rep: 1168 Posts: 3,270
It's a great idea for maintaining lightness. SOF can be designed in the building process by starting with a midsection shape and stem/stern and working from there. It allows a constant analysis and opportunities to make changes. Simply spread or pinch in stringers between midship and ends using whatever and see how it flows to the eye.
A boat built to go fast will need to be a bit huskier than typical SOFs are. This will put it in the weight range of good cedar stripper or kevlar/ carbon builds, which isn't bad since the SOF is dirt cheap to build.
The whole 2-man boat with outrigger and sail should be under 100 lbs even ruggedly built, and possibly as light as 80 lbs, I think.
Use a windsurfer luff pocket sail and carbon two-piece mast and it should go like a rocket.
Old 08-01-2009, 03:18 AM
Rep: 10 Posts: 50
Thanks Alan for your answer.
actually, I don't want a sailing outrigger, but a mere paddling one.
Just as I said formerly a V6 downsized to 2.
My canoe should stay in the 20 kg range main hull alone, for ground manoeuvring ease.
If it's possible with a stitch and glue build, I'd rather go on this for strengh, otherwise SOF will be my choice.
I wonder if SOF will be stiff enough on the wave.
Skin on Frame Raft djwkd Wooden Boat Building and Restoration 10 03-25-2010 05:52 PM
Skin-on Frame Kayak Building Jig alan white Wooden Boat Building and Restoration 90 11-20-2009 10:55 PM
Outrigger canoe plan.... BWD Multihulls 31 09-09-2009 01:46 PM
Fabric skin over frame construction sailsocal Boat Design 4 02-24-2009 07:13 PM
Expedition - skin on frame kayak for sale dirtybeard Marketplace 0 06-12-2007 10:48 AM
