Old 11-14-2005, 08:29 AM
cyclops cyclops is offline
Rep: 33 Posts: 1,059
The key to SS has always been keep them dry. Hell, why use them at all in water applications? Also, they DO stain and discolor with common cleaners , drinks and food dropped and accidently left on them. Soda spills are VERY bad. SS does NOT mean stainless in any way. Read some tech. specs about the various types. Bronzes and synthetics are far more reliable. That is why the glues are pushing all metal hardware out of most jobs they have enjoyed.
Old 11-25-2005, 06:56 PM
luke bronco luke bronco is offline
Rep: 10 Posts: 15
HI just wanted to say that we are a U.S. manufacture of cut thread wood screws we can make them in any material for you with any drive from sizes ranging from #2 all the way to 24 x 6'' long and all kinds of quanties im looking to start stocking common sizes. id be have to get the chance to quote some screws for you or maybe hear your ideas on some good common sizes to start stocking hope your interested thanks Luke
www.oemfasteners.net
Old 11-26-2005, 01:20 PM
chandler chandler is offline
Rep: 16 Posts: 378
luke bronco: racehorse or pornstar?
Old 02-03-2006, 06:41 AM
jcleese01 jcleese01 is offline
Rep: 10 Posts: 3
Monel 400
I was reading all the posts about how silicon bronze is the better material for most applications and how stainless is not as well suited for structural purposes, but I was wondering how Monel rates as a wood screw material? I know that Monel is very corrosion resistant, and very strong but is it better than the silicon bronze, or does it rate more like the stainless.
Old 02-03-2006, 12:00 PM
PAR PAR is online now
Rep: 3125 Posts: 9,403
Monel, (typically a third copper and 2/3's nickel, though 10:90 mixes are available) is a great material and is similar in strength to marine aluminum, though weighs somewhat more then steel at 530 lbs. cu. ft. It is pretty much immune from the effects of the marine environment and hull plating can be left bare. It's quite costly and should be sized on a scale similar to aluminum. I've seen monel fasteners and use staples and brads of the material, regularly, but bronze is stronger and less costly, so it's a simple choice.
Old 02-03-2006, 05:13 PM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
In NOrway we use to say "copper rows" or spikes or clenches. Is this pure copper?
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 02-03-2006, 07:29 PM
The only roves or clench nails I've used have been copper, though I wonder if monel would make a stronger clench. Seems like it would, but likely at triple the cost.
Stainless V Strut vs Bronze V Strut jameshogan Materials 7 05-17-2009 07:03 PM
Stainless steel / Aluminum hendrikus Boatbuilding 5 06-30-2006 06:40 PM
Stainless steel properties jonathan Materials 9 03-31-2005 12:15 PM
Stainless steel protection on small vessel keels Gilmarine Fiberglass and Composite Boat Building 1 02-20-2005 10:51 AM
Stainless Steel hull? trouty Boat Design 3 11-18-2002 02:57 AM
