Old 09-15-2010, 05:37 PM
creativeglenn creativeglenn is offline
Rep: 10 Posts: 4
Shanty/Pontoon Boat
Hi I am considering building a modern version of a Shanty boat from plywood.
I want to live on the canal but find the cost of steel narrowboats very high.
I like the look of the old Shantys and wondered if this kind of thing would be possible.
I am thinking of using timber frame but not sure what to go for.
Should I use nails or screws?
Should I epoxy the bottom?
Any ideas would be appriciated.
Thanks.
Old 09-15-2010, 09:40 PM
PAR PAR is online now
Rep: 3125 Posts: 9,403
Purchase a set of plans and stick to the materials list and construction details.
I take it that you aren't going to use a GRP hull, strip it out, then make it suit your needs. From a maintenance point of view it would probably be better if you use the GRP hull, particularly with a shanty, which typically wouldn't have the routine maintenance preformed as a yacht would. In short, wood maybe easy to work with, but it can tolerate neglect the least, so wouldn't be the wisest choice for a shanty hull in my opinion.
Again find plans. I don't have plans for a shanty type craft, but there are many places that do. Naturally, most of these will be plywood over frames, which I think is a poor long term choice for this type of craft, but conversions could be made, as well as heavy external 'gless sheathing.
Shanty type boat need advice/opinions BuildingaLemmy Boat Design 9 08-19-2010 06:46 PM
Lake Michigan Shanty Boat johnnymitch74 Boat Design 22 12-18-2009 02:14 PM
House/Shanty shortcut question... Gravquian Wooden Boat Building and Restoration 2 11-29-2008 03:20 PM
8 foot wide shanty boat jrl5678 Stability 43 07-21-2007 11:16 AM
Trailerable Shanty Boat dick stave Boat Design 2 11-12-2006 02:46 PM
