Sealant for plain plywood
Discussion in 'Wooden Boat Building and Restoration' started by eye4u, Jun 7, 2010.
  1. DrCraze
    Likes: 6, Points: 0, Legacy Rep: 33
    DrCraze Junior Member
    Use some styrofoam and form blocks for the area to receive them then sheath them in 3 layers of wire mesh and coat with a cement plaster. At 3 layers of mesh the concrete weighs 3lbs per sqft equal to the weight of 3/4 inch ply.
  2. ancient kayaker
    Likes: 147, Points: 0, Legacy Rep: 2291
    ancient kayaker aka Terry Haines
    You don't really have to close off the bottom of the box if you are filling it with foam, unless you have to pull it out of the water for Winter, so a simple 2 x 4 frame around the sheet of insulation will be sufficient protection.
