Old 02-20-2006, 07:38 PM
Comet Comet is offline
Rep: 10 Posts: 13
Screw Hole Repair
What is the best way to repair the stripped screw holes in a wooden boat? The boat is a Comet from the early 40's in original condition.
Thanks!
Old 02-20-2006, 07:57 PM
Oyster Oyster is offline
Rep: 90 Posts: 233
We could use a few more details. What is stripped, the holes in the frames or ribs, or just the screws spin in their holes? It the heads stripped off of the fasteners? Have you examined the fasteners? Are they original? Questions that may or may not be relevant to the job, too. How did you come about asking this question?
Old 02-20-2006, 08:24 PM
Rep: 10 Posts: 13
I've just started this restoration. Today I removed the rubrails and the deck canvas.
Of the 46 original (apparently bronze) flat head screws holding the mahogany rubrails in place one was a "spinner" and two others had been knocked to the side elongating their holes.
As this project progresses I’m sure that I’ll find more screw holes in various places needing repair. I’m looking for an overview.
Thanks.
Old 02-20-2006, 08:37 PM
Rep: 90 Posts: 233
I don't know the boat. But if you are having the problem in the rubrail area, with spinning screws, it sounds like the wood has just dried out. One thing that you can do is when you remove as many screws as possible, and wish to make sure that the rails are secure upon going back with your original rails, just plug the holes in the wood with bungs, at least every other one, and drill new ones. Of course this depends on the spacing of the original screw holes. You do not have to use screws in the original holes. Just plug them up. A lot of people will drill the holes completely out, over size, plug them wilth dowels to make sure that its all solid wood, too.
Old 02-20-2006, 08:48 PM
Rep: 505 Posts: 1,658
take some toothpick size pieces ..or slightly larger ,almost filling the gap, put them into the hole ,,,and reincert the screw,just make sure you use a marine type wood,,,,when it gets wet it will be as good as ever. if not better.
Old 02-20-2006, 08:55 PM
Rep: 10 Posts: 13
thanks, I have mahogany from the damaged rubrail
Old 02-20-2006, 09:00 PM
like oyster said its probably just dried out a little.,,a few drops of linseed oil will help untill it gets wet ,,,,,,,,,good luck ,longliner
Old 02-21-2006, 08:56 AM
Rep: 10 Posts: 13
thanks again guys, I may have new rubrails milled and mount them using new screw holes...should the old holes be filled or sealed? if so with what?
Old 04-02-2006, 10:39 AM
VKRUE's Avatar
VKRUE VKRUE is offline
Just another boat lover
Rep: 64 Posts: 254
Should Old Holes Be Filled ???
Hello Comet... Yes, absolutly ! I'm not a boat designer or builder but, I am restoring an old wooden boat of my own... a 1960. In my research and studying I have determined that ANY hole that is left unsealed is a trap for water to gather. When I removed my rubrails I mixed up some "THICKENED EPOXY" and dipped my dowel pegs in the thickened mixture then lightly tapped these pegs into each hole, completely sealing the holes. Later I came back and cut off the excess peg protruding. Will replace with new rubrail using new holes offset from the original ones. NO HOLES OR CRACKS LEFT OPEN OR UNPLUGGED ANYWHERE ON THE BOAT ! No place for water or condensation to accumulate.
Hope this helps.
VKRUE
Old 04-05-2006, 09:47 AM
Rep: 10 Posts: 13
Thanks for the reply...I plan to take your advise.
Proper screw size? byankee Wooden Boat Building and Restoration 2 02-19-2006 02:18 AM
Displacement hulls, twin screw more econimical than twin screw? JohnJewel Propulsion 11 01-09-2006 12:40 AM
Broken Screw Potterage Fiberglass and Composite Boat Building 0 09-23-2005 04:33 AM
High-Speed Waveless Screw waveless Boat Design 4 08-05-2005 10:56 AM
Hole 01pinkfloyd Boat Design 2 05-08-2004 07:16 PM
