| Scarfing Ratio Looking at scarfing some Sitka spruce together for stringers. Anyone suggest the best ratio - 1 in 12, 1 in 16, etc. Thanks again |
| Thanks for the information; interesting reading indeed. Looks like it can be summarized as 8 to 1 minimum. |
| Even 6:1 (minimum) can be ok for frames and keels, if you have good woodworking and glueing skills. Below that, a scarf should be reinforced. |
| As pointed out the 8:1 thread, the ratio depends on a few factors. Lightly loaded and/or bent elements can use a steep slope scarf, but more heavily loaded and/or tighter radius bends require a shallower slope. Try to position the scarfs in relatively flat, straighter areas of the stringers if possible. |
| Scarfing Techniques | TJPERKINS | Boat Design | 4 | 12-04-2010 04:48 PM |
| advice on scarfing hog | H248801 | Wooden Boat Building and Restoration | 3 | 12-06-2008 08:20 PM |
| Built a scarfing gjg! | BHOFM | Wooden Boat Building and Restoration | 10 | 08-07-2008 02:42 AM |
| Scarfing hints? | ted655 | Wooden Boat Building and Restoration | 14 | 08-02-2008 07:45 PM |
| Scarfing Jig | qadeer | Boatbuilding | 13 | 01-03-2006 06:01 PM |
