Old 12-17-2004, 08:44 AM
Baycat Baycat is offline
Ric
Rep: 10 Posts: 9
Scantling rules for stitch & tape
I am looking at Stitch & tape technique for a new design of approx 24-26 feet was wondering if there was a book that provided 'scantling' sizes for this
( for example does Dave Gerrs - (westlawn) book provide this ) this seemed a better way to go than emperically applying the thicknesses from someone elses plans. I am not an engineer so would need information in a form that suits the layman.
Is there a previous thread or can somebody help thanks.
Old 12-18-2004, 02:24 PM
Rep: 48 Posts: 638
Baycat,
I don't believe the scantlings will be very different using the "stitch and glue"-methode or an other contruction methode, provided all methodes are using the same construction material.
For this lenght of vessel there is also not really a "rule" or formula to calculate the construction, look for similar designs of the same construction material over a range of lenghts. Based on that you can make a good assesment of the scantlings you need.
Good luck.
Dutch Peter
Old 12-18-2004, 09:25 PM
Rep: 494 Posts: 3,841
Dave Gerr's book has that info.
Old 12-19-2004, 09:11 PM
Ric
Rep: 10 Posts: 9
Thanks Gonzo - now just to get a copy here in Australia - snail mail thru the local book retailers I guess, not quite ready to enrol in the course yet, or do I need to enrol to make sense of the book? I do have a degree in architecture but there's not much engineering in that.
Thanks Dutch Peter I did look at the option of purchasing say an Arch Davis or Bateau design of a similiar sized boat and using those principles in the new design but it seemed a bit like guessing to me
thanks again
Old 12-19-2004, 10:58 PM
The scantling rules are very straightforward. You enter the dimension of the boat and it gives a scantling number. You then enter this number for the dimension of every part of the boat.
Old 12-20-2004, 01:25 AM
Ric
Rep: 10 Posts: 9
Gonzo - thanks again
Do I need to use tape on the joints of a mirror? DMShone Materials 3 07-08-2005 01:00 AM
Birsmouth mast & carbon fiber tape Robert Miller Wooden Boat Building and Restoration 1 05-23-2005 06:02 PM
design scantling rules guest123 Boat Design 1 12-03-2004 10:06 PM
Simpson's Rules (and others) Mike D Boat Design 13 05-27-2004 07:59 PM
Transom Scantling Baz Boatbuilding 4 01-26-2003 06:14 PM
