| Safe Engine Removal I am about to pull the KFL out of my '58 CC and need suggestions as to a safe way to do this without, damaging the engine, my ceiling or myself? Anyone? ![]()
__________________ ><(({(o> ><(({(o> ><(({(o> ><(({(o> ><(({(o> ><(({(o> <o)3))}< ><(({(o> ><(({(o> ><(({(o> ><(({(o> “You cannot sink someone else's end of the boat and still keep your own afloat.” |
| You'll need a hoist system strong enough and steady enough to hold several times the weight of the engine. If you don't have access to an overhead crane, you might (with some careful planning and calculation) be able to build a couple of timber A-frames, with a really beefy cross-bar between the tips and a lot of diagonal bracing. You could mount a chain hoist on such a rig if it's built heavily enough. The rafters of the average garage will not hold a big engine.
| If we had to we would get a few deckhands and carry the volvo 210 s out by hand ,how heavy is your engine? can 4 or 6 guys and a few beers carry it out? |
| you see now adays eveyone needs a machine or gismo to do something, but I will say I can tighten a bolt with a cheaterpipe tighter than a air tool, less than 100 kids moved my 32ft sailboat.and turned it over. dont under estimate manpower,,,,,,,,longliner |
| What about a standard 2 ton shop crane? I am unsure of their reach and height. I will probably build an A-frame set-up using a two 2x12 for the header and 4x4s for the legs
Sam |
| they glassed the outside of the hull, by the way Texas boater I didnt mean to come off as a jerk ,but looking back ,,,,,,,well, anyway how big is your engine?I know you dont want to remove decking ,but is that a option? |
| safe temp for a Perkins 4108 50hp????? | MarioCoccon | Sailboats | 16 | 03-14-2008 11:49 PM |
| railing removal | bertram28 | Fiberglass and Composite Boat Building | 0 | 10-18-2005 11:50 AM |
| Safe Remote Fuel System for boats | tom kane | Open Discussion: All Things Boats & Boating | 7 | 04-04-2005 11:36 PM |
| Average Human Weight, Safe Excess Weight, &c. | Free Pirate | Boat Design | 12 | 03-14-2005 02:40 AM |
| fiberglass removal | repmark | Wooden Boat Building and Restoration | 4 | 08-09-2003 11:57 AM |
