Old 02-18-2010, 10:09 AM
pescaloco pescaloco is offline
Rep: 67 Posts: 243
rot resistant wood question
Hi
Allthough the application is not for a boat I'm sure sombody will have a suggestion or two.
What is needed is a rot resistant wood for use in the construction of floating bait barge boxes in saltwater, would like a wood available in the South western USA or Baja Mexico. Materials will consist of some 2x4 material 2x6 and a lot of strip plank type material 1/4 or 1/2 in thick by 1 in wide by 8 to 10 feet long. Any suggestion would be appreciated, even means of assembly meaning faster type or technique.
Thanks
Old 02-18-2010, 10:23 AM
GG's Avatar
GG GG is offline
offshore artie
Rep: -30 Posts: 190
Originally Posted by pescaloco View Post
Hi
Thanks
Coosa is a material that is stronger then wood lighter and will never rot put you might need some assembly for achieving the desired thickness that you want and it can be purchased from here www.advanced-plastics.com
Old 02-18-2010, 11:07 AM
rasorinc rasorinc is offline
Rep: 687 Posts: 1,175
composits qre the only wat to go for you. here is a source of HDPE. For fasteners use Silicon bronze for salt water exposure.
http://www.inlandplywood.com/SEABOARD.htm
3M makes a specific adhesive for HDPE.
Old 02-18-2010, 06:17 PM
The copper guy The copper guy is offline
Rep: 10 Posts: 85
The plastic wood as above is the best for your purpose' Coosa or other.
It can be shaped/Bent/twisted etc with the use of a simple heat gun????
However if you want wood CYPRESS is of coarse unbeatable this wood is from the swamp and in the swamp"s they use it for everything!!!!
You may want to consider fastening with copper ring nails (you will have to pre drill.
Whatever you fasten with, Dew to much handling they will require something
more. (a short peace of canvas fire hose on each corner?)
Also some kind of hinge will be needed???
My suggestion would be webbing? also attached with copper ring 1/4inch(nylon rope will rot in the sun)Canvas webbing will last a long time(Fire hose again perhaps??) This would also make good fending around the box.
If you are shore based why not set up a tank with salt water pump"s
I worked in a bait shack and set up several such tank"s and i also have a list of suppliers for the copper ring nails.
please don't hesitate to contact me if you need anything. The copper guy
Old 02-18-2010, 06:58 PM
Boston's Avatar
Boston Boston is online now
Rep: 1457 Posts: 3,357
you might check out white oak ( which I have laying around )
I am skeptical of the deniers diatribe
Old 02-18-2010, 09:38 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
White oak is heavy but won't rot easily, especially in salt water. Yellow pine, pressure treated and available anywhere, will be somewhat lighter and it will last almost indefinitely without rotting. Cedars are probably not tough enough though they are very light and relatively rot resistant.
Plastic has poor stiffness, tending to sag over spans that would be no problem for real wood. Plastic is expensive too. It is, however, inert, and underwater, it won't decay. The sun can break down plastic over time.
Old 02-18-2010, 09:42 PM
Boston's Avatar
ya I would not recommend plastics either
we have enough of that stuff floating round in the oceans already
Old 02-19-2010, 06:15 AM
CDK's Avatar
CDK CDK is online now
retired engineer
Rep: 1425 Posts: 2,253
There is a tropical hardwood called meranti. Reddish brown, doesn't rot and is not attacked by insects. One of the few types that can be used outside without any treatment. Cheaper than oak, but very strong and also heavy.
Old 02-19-2010, 09:16 AM
Rep: 67 Posts: 243
Guys thank you ALL for the suggestions.
I was thinking pressure treated for the demensional lumber, but did'nt know for the slat material. Alan is your suggestion plain Yellow Pine or is it a pressure treated material ?
Where does a person get high quality fasterens these days that are not Chinese junk ? No offense to the Chinese ofcourse.
Old 02-19-2010, 09:29 AM
Hunter25 Hunter25 is offline
Rep: 46 Posts: 173
Use pressure treated throughout your project. This is what it was designed for but you should check to see that the CA poisons used to treat the lumber will not kill your bait too. The thinner stuff you were asking about can be ripped from 2 x 4 or 4 x 4 material. Special screws need to be used with the new PT lumber treatments. All big box stores carry these types of screws, but check for submersion compatibility.
Rep: 10 Posts: 85
whatever you do do not use pressure treated wood it will kill your bait m8
Old 02-20-2010, 09:37 AM
Rep: 67 Posts: 243
Thank you !!!!!!!!
We are in the begining stages of researching this
Old 02-20-2010, 01:44 PM
Boston's Avatar
go with a naturally rot resistant wood
white oak
black locust
cedar
your bound to get better results
cheers
B
Old 02-20-2010, 09:54 PM
alan white's Avatar
The fact is, finding untreated yellow pine is not as easy as finding the treated stuff. I see no problem with pressure-treated. Look for moderately dry suff with few knots and straight grain. Your particular needs are not too critical. pick through the piles, and avoid box stores. They store the wood indoors, which causes the wood to warp. Check out lumber yards that store the stuff outside under a shed roof.
If treated wood kills bait, try if you can to get some untreated yellow pine. In salt water, it does well and it's a tough wood.
Old 02-21-2010, 10:09 AM
Rep: 67 Posts: 243
Thanks Guys
You know Allan I never put it together that box stores indoor climate made their wood warp and cupp, just thought it was junk...........that makes sense
thanks
Dealing with Mold and Rot inside a Wood Hull TheSound Wooden Boat Building and Restoration 23 02-18-2010 07:37 PM
Newb question - Dry rot mrmarkos Fiberglass and Composite Boat Building 11 04-04-2009 12:00 AM
Are one part polyurethane topside paints gas resistant sbklf Fiberglass and Composite Boat Building 6 08-02-2007 11:14 AM
Are one part polyurethane topside paints gas resistant sbklf Materials 1 08-01-2007 08:55 AM
Blue 7- a wood-rot killer, now discontinued. ??? hansp77 Wooden Boat Building and Restoration 4 08-24-2006 09:53 PM
