Old 06-25-2011, 07:04 PM
learningtheway learningtheway is offline
Rep: 10 Posts: 14
Rib width for a 13-14 foot boat
Hello again,
Ive never built a boat before and the plans im looking at say to use 1x8(oak) to build the ribs of the boat. My first reaction was to wonder if that was too small or skinny to use for the ribs.
The boat is 13 feet and it is v bottom in shape fishing boat
Thanks
LTW
Old 06-25-2011, 10:14 PM
aka Terry Haines
Rep: 1814 Posts: 3,009
Too many variable so far, LTW: suggest you ID the design and type of boat, and what you intend to use it for. Boat designs vary from having no ribs at all to lots of tiny ones close together and they can all produce a seaworthy boat.
p.s., also the construction method would be useful information
Dances with Turkeys
Old 06-26-2011, 03:01 AM
judgegage judgegage is offline
Rep: 18 Posts: 24
Ok, for a 13' boat 1x8" oak be more than strong enough. ancient kayaker is right there are alot of variables. I wouldn't go more than 24" between ribs. So, about 4 ribs on a 13' boat.
The first duck boat I built was about 11' oal and 4' almost flat bottom. I used 1x4" pressure treated pine. I beat that little boat for 3 years crossing our bay and it was as solid the day I gave it away as when I built it. The kids I gave it to used it for a few more years before I lost track of it.
Hope this helps.
fixing one foot diameter hole in Ferro Hull 32 foot luckyscott Materials 17 01-21-2011 01:45 PM
Boat width - You can tow 'em wide here tom28571 Boat Design 6 09-28-2008 02:27 AM
Dual Width Boat Design Al Tyler Boat Design 2 02-14-2008 10:54 AM
Guildlines for measuring boat length and width kach22i Boat Design 14 10-08-2007 07:19 PM
boat width grp.boat Fiberglass and Composite Boat Building 1 06-14-2006 06:30 AM
