Old 08-20-2010, 12:11 AM
aka Terry Haines
Rep: 1814 Posts: 3,009
Reverse Clinker Construction
While recently reading "Clinker Boatbuilding" by John Leather I found a brief description of reverse clinker construction, in which the planks are added from the sheer down, ending with the garboard. Some enthusiastic claims are made or reported by Leather.
I also found some refences on the internet but only a few fuzzy pictures which show the planks laid horizontally. However, Leather states the planks are laid from the transom to the sheer, so that the planks are diagonal, although no picture is provided.
Does anyone have any experience, images, or other information on this concept?
Dances with Turkeys
Old 08-20-2010, 12:34 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,055
Interesting.. and never heard before either. Made a search an found http://en.wikipedia.org/wiki/Compari...ing_Traditions
http://www.informaworld.com/smpp/con...ent=a728555675
http://onlinelibrary.wiley.com/doi/1...345.x/abstract
Maybe she is the person to ask more.. http://www.southampton.ac.uk/archaeo...iles/blue.html
Old 08-20-2010, 05:30 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 596 Posts: 1,026
The most common examples I've seen are on clinker built ski boats but only for the No. 1 plank & the garboard, the rest usually planked from No. 1 up.
Old 08-20-2010, 01:53 PM
aka Terry Haines
]The description in Wiki is incorrect, it merely distinguishes between straight nailing and clenched nailing and misses the point about the order of the planks.
The claimed advantages and my comments are:
1. No standing water inside the hull - but lots of it outside?
2. For sailing, more resistance to leeway from hull - but more drag
3. Additional lifting force leading to reduced wetted surface - presumably this applies to diagonally planked hulls
4. Easier to clean out - I don't get this
5. Easier to see the planking lands doing during construction - I don't get this either
Frankly I think the idea has earned its obscurity, but I thought there might be something in it. Of course, I haven't owned or built a lapstrake boat so I don't have a practical perspective on it.
Dances with Turkeys
Old 08-20-2010, 02:46 PM
peter radclyffe's Avatar
peter radclyffe peter radclyffe is offline
Rep: 576 Posts: 1,066
4, the dirt does not lodge so badly
5.you can see the edge fay to the last plank
Old 08-23-2010, 06:37 AM
Rep: 1493 Posts: 7,447
That would be like making repairs on a clinker. You have to slide the planks under the top one. It is very difficult and slow. SeaSkiffs and other boats had reverse planking on the bottom which made a shingle or stepped surface. It makes the boat have less resistance on a plane.
Old 09-03-2010, 08:47 PM
Riccelli Yachts's Avatar
Riccelli Yachts Riccelli Yachts is offline
Yacht designer & Builder
Rep: 190 Posts: 10
I've repaired a couple of boats with reversed laps, but these were powerboats and the reverse was only on the bottom planks. At the turn of the bilge they converted to the usual direction. The reason for the reverse lapped bottom is simple, it offers several "sheering" edges, to get the flow to separate cleanly and quickly. It makes for a faster boat with the same amount of power, compared to a carvel or conventionally lapped hull of similar shape.
Planking repairs or new construction would be the same, though reversed laps would likely be "planked backwards" too, if new construction. Repairs wouldn't make any difference, as a shutter plank, is a shutter plank and they all suck if you've never done one before. I remember my first and I hung the darn thing 5 or 6 times, before I got it right.
The reversed lap fishing sailing craft seen in the far east are but a natural arrangement of the planks, to help prevent water, pushing through the seams, in their way of looking at things.
40+ year old clinker restoration gusblake Wooden Boat Building and Restoration 3 02-24-2010 07:31 AM
Clinker boat design gusblake Boat Design 17 09-11-2008 07:54 AM
26' clinker lifeboat zero Wooden Boat Building and Restoration 11 07-21-2006 04:56 AM
Refastening clinker hull Andy Wooden Boat Building and Restoration 3 03-29-2005 09:36 PM
Clinker Hull Design edward Boat Design 2 03-25-2005 10:06 PM
