Old 06-29-2010, 04:54 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
...from memory, we used a cord as the centre lever point, that way it was height adjustable easily. Sone days the lever is required more than others, and changing the angle of attack proves beneficial.
Old 07-01-2010, 11:20 PM
pamam pamam is offline
Rep: 10 Posts: 20
Restoring a VJ
Brian,
Thanks for the dimemsions of the plank rail. I will try to put it all together on a drawing and email it to you. My email is pamam@qcsindustries.com. I have your email in my book so it won't go to the Junk folder.
Thanks again.
Mel
Old 07-02-2010, 11:42 PM
Rep: 10 Posts: 20
Restoring a VJ
Brian,
Attached is drawing of my understanding of what you sent me about the plank rails.
I have a couple of questions.
1. the 7 holes 10X15mm holes are how deep into the rail?
2. are the holes in 1. for lines for the jib or spinnaker sheets or some such?
3. the extra 40X48X17 hole: is that for a cleat of some sort?
4. how is the rail attached to the deck?
5. how is the leather attached to the rail?
Old 05-16-2012, 03:37 PM
Rep: 10 Posts: 20
It's been a while but the boat is coming along.
Brian,
I have been hard at work on both my mustang and boat. I have the hull bottom and sides done and am placing the reinforcements for the rigging in the hull. After this I will place the top and paint/fiberglass the finished hull. then add the rigging etc. I had to add the bump in the transom for the rudder housing which was >200mm while the deck height at the transom was only 102mm. Anyway, I post more info when I get further along. I'm hoping to go sailing this summer around August.
Mel
Old 05-16-2012, 09:35 PM
brian_n brian_n is offline
Rep: 10 Posts: 13
Hi Mal
Seems we are up to about the same stage. I have to replace my entire deck as the brass screws had ruined the ply. This made the replacement of the outside gunwhales a must as the screws had weakened them too badly. As well the mainsheet eyebolts were only chromed steel which had corroded so badly that I had to pull out the bottom of the cockpit to replace them. They were fitted right through the keel and the damage to this timber had to be made good since the nuts were on the outside. I have laminated new gunwhales and fixed the keel and its rubbing strip. The bottom of the boat now has four coats of varnish and is looking beautiful. She is about ready to turn over for the new deck and deck fittings. The fittings will be fun as I dont know where they go. I just have a box of S steel bits and a few holes in the deck beams to go on. I notice a slight differance in your stem from the photo. Mine has a small bump on the top which fits into a recess in the bottom of the bow sprit to locate it. I dont think it was fastened there as well. They relied on the fastenings at the aft end and the bobstay to hold it in position. Anyway good to hear from you and good luck. It's getting quite exicting.
Brian_n
Old 05-17-2012, 11:20 AM
Rep: 10 Posts: 20
Picture of placement of fittings.
Brian,
Here is what I got from my friend in Australia. It is a rough sketch but it will help with almost all of it. Here is his email if you have any questions.
Greg Fryer [greg@fryerguitars.com], yes he has a guitar shop. Greg and his friends have or are in the process of rejuvinating the VJ club in Lake McQuarry area: of course they are using fiberglass and carbon fiber these days. That will be my next boat.
Mel
Restoring a VJ-big-apple-iii-layout-1993-2011.jpg  Restoring a VJ-big-apple-iii-leaning-plank-setup.jpg
Old 05-20-2012, 01:27 AM
Rep: 10 Posts: 13
Thanks Pamam good info re placement on the sketches. I notice that you are using stringers. On my old set of plans they are not used. Humalong had them but they were made very badly from strips of ply which were not glued down to the skin. [ The glue had failed ] I took them out as they were doing nothing but could replace them with something which would work if needed. My question is, how thick is the ply in the bottom of your boat Mine is 5/32. My feeling is, given the short distance between the frames, I wonder if they are really needed.
Restoring this boat, But who made it! ChuckB Powerboats 0 08-25-2009 01:27 PM
Restoring 12' Dinghi HoustonB Boatbuilding 14 06-06-2007 10:19 PM
New to restoring boats jessper Materials 3 05-06-2007 12:10 AM
Restoring a Quarter Ton D'ARTOIS Wooden Boat Building and Restoration 12 09-13-2006 05:31 PM
Restoring a Fiberglass Deck Joe Wood Fiberglass and Composite Boat Building 1 09-10-2006 12:04 PM
