Old 11-08-2006, 05:37 AM
piogil piogil is offline
Rep: 10 Posts: 2
Replacing Plank...
Hi all, somebody know where could I find (in the web) graphic information (illustration, pictures...) about the replacing plank method.
I own a 1947 cutter, hull in oak, and I need replace few pieces of plank surrounding a rotten original bronze thru-hull....
iīve read a couple articles... but my english is not so good and i donīt understand the half......
Thanks in advance...
Pio
Old 11-09-2006, 04:01 AM
dr.j dr.j is offline
Rep: 10 Posts: 27
What type of construction is your boat? If it is carvel planked then you should be able to accomplish the task yourself provided the area of concern is not in a difficult area. Areas that have a great amount of curve are best left for those with experience.There are tools and techniques involved that the average Joe might not possess to perform this task. A steam box will probably also factor into the equation. If you really want to do this yourself,then ensure that you do as much research as possible. A person could probably perform heart surgery if he had enough empirical knowledge...
Old 11-09-2006, 04:15 AM
Rep: 10 Posts: 2
Thank for your advise dr.j. I need replace just a a meter or so in three or four plank in a almost straight area. I never have done this kind of work in the hull and i´m little afraid about the result... in the other hand i can´t paid a professional carpenter. I need more information.. graphical specially
Old 11-09-2006, 05:29 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 513 Posts: 940
Piogil, buy a book such as Robert M Stewards Boatbuilding Manual, it sets out the planking butts etc required & heaps of other useful stuff, having a real text to refer to is good comfort in repairs. Don't be tempted to "short plank" your repair by crowding planking butts close together & "saving?" work & timber, you've gotta stetch your planking repairs out along the hull so as not to have butts less than 3 planks between or 5 frame spaces along the hull, more if possible, & your best to go to existing butts if sqibby(small) are left as result of repair plank lay out. Some planking types can be glued-scarfed but although I have no experience of Oak here in Australia I doubt it would be a candidate for this, other forum contributors will be more experienced in this. Regards from Jeff.
DuFLEX strip plank mojounwin Materials 3 12-04-2007 06:34 AM
Clinker plank replacement Andy Wooden Boat Building and Restoration 5 01-08-2006 08:47 AM
replacing wooden plank ajoan Wooden Boat Building and Restoration 6 11-07-2005 09:41 PM
strip plank technique pingert Wooden Boat Building and Restoration 7 07-24-2004 02:58 PM
strip plank construction jimo Sailboats 2 05-26-2004 06:11 AM
