Old 09-24-2009, 11:41 PM
simon simon is offline
Rep: 42 Posts: 79
Repairing wet strip planks.
Hi,
my boat is WRC strip planked. Around some of the skinfittings there seems to be some water entering the wooden core due to unproperly bedded fittings. The moisture meter shows elevated content in direction of the strips, measured on the inside of the hull.
We are going to peel off the outer fiberglass layer around the fitting in the way of the strips to get an idea of the condition the wood is in. If the wood is in good condition, I was planing of letting it dry out and then put the glass back into place with epoxy. The wood around the skinfitting will be sealed with epoxy, so that if will not happen again.
I would be gratefull for some feedback about the proceeding. Is there any adherence problem if the wood was soaked with salt?
Thanks
Simon
Old 09-25-2009, 01:21 AM
Rep: 1133 Posts: 4,714
Your plans seems good, get the glass peeled back and dry out the lumber. I like to bond hull penetrations, so this doesn't happen again. Bonding doesn't mean glue things on. What it means is you mold an epoxy "ring" at the penetration point, so if there is a leak, it's just a leak, not soaking into the wood.
In a nut shell what you do is drill an over size hole, wet out and fill with thickened epoxy, let dry. Then drill for the correct size hole, but within the confines of the epoxy. Now a leak will just be a leak and the wood is protected by the epoxy.
Scuff up the surface and wet out the wood, before putting on the 'glass patch, the epoxy will work fine.
Old 09-26-2009, 09:13 PM
Rep: 42 Posts: 79
what about the tactics west system is suggesting, drilling 5mm holes every 25mm through the outer laminate into the core, drying out the area and then filling the holes with epoxy?
Simon
Old 09-27-2009, 01:36 AM
Teddy
Rep: 405 Posts: 992
You can try that first and take new moisture readings after a while.. This proces could be boosted vacuum pumping on the other side and having vent holes on the other..
Old 09-27-2009, 07:28 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 292 Posts: 1,218
If you apply vacuum over the holes - it will remove a lot of the moisture.
A vacuum is the equivalent of freeze drying
Old 09-27-2009, 09:09 AM
Simon, West's technique is more to repair compromised cores. This core is just wet, so far as we know. Using duct tape, plastic sheeting and a dehumidifier can expedite the drying out process too.
Old 10-03-2009, 02:37 PM
Herman Herman is offline
Rep: 82 Posts: 299
Western Red Cedar is a very durable wood species (40 years in ground contact durability) so I would not worry too much about the planks. Now just get them to dry using the above suggestions.
The ingresspoint can be rinsed with fresh water to get rid of the salt. When dry the epoxy should bond without problems.
If all else fails, there are types of epoxy that adhere very well to wet wood.
Old 10-29-2009, 11:14 AM
Rep: 42 Posts: 79
Thanks for the advices.
We have stripped the glass where there were elevated moisture readings. After 3 weeks, the readings were low enough to allow putting the fiberglass back on again. The cedar was still good enough, so that it could be left in place.
Old 10-29-2009, 12:25 PM
Rep: 82 Posts: 299
Good to hear all worked out well.
Speed Strip tongue-and-groove strip planking Jeff Materials 38 08-05-2009 12:12 AM
Planks, Plywood?? BHOFM Boatbuilding 4 07-30-2008 09:27 PM
Repairing Strip Planking Brands01 Wooden Boat Building and Restoration 5 03-07-2007 01:34 AM
caulking planks JimHog Wooden Boat Building and Restoration 3 10-29-2006 05:03 PM
planks treatment peter g. Boatbuilding 0 06-25-2004 08:00 AM
