| Removing hull from forms How much internal framing is needed to keep the shape of a strip planked hull? I need to get the outside glassed before cool weather arrives. I will add the stringers and floors (9 mm plywood). If I add a keelson then I can not lay glass across the center joint. The photos show the bulkheads with notches for the stringers. The hull half is laying on its side. This is a catamaran hull. Thanks for any comments |
| Bump, maybe someone will have a good answer for you. Question tho, what is your reasoning for such a large number of stations? LOA? |
| To add, I like your model. Very good design of shape I think. Have you filleted your bulkheads? From a purely amatuer POV I would believe that shape would be retained by the glass on the inside. |
| Being an amature myself; I set the forms at 50 cm spacing because it made less of a chance that I would screw up when setting them. (dislexic sometimes) LOA is 14.5 meters. LWL 13.8 meters BWL (of one hull) 1 meter I have added 2 stringers. one at the DWL and one 20 cms up from the DWL. Figured that if I hit something floating this is where the loads will build up at. I wanted to add the keel and keelson before lifting it out. Decided it will be better to do that when the halves are already joined. No one with advice? |
| Hull speed | Mike D | Boat Design | 33 | 02-27-2011 02:20 AM |
| How about boat design definitions | JonathanCole | Boat Design | 55 | 01-24-2010 05:48 PM |
| Luhrs T-29 (1995) diesel inboard converted to outboard | Iya | Boat Design | 13 | 03-07-2007 07:48 PM |
| Jet Drive | Jet Drives | 15 | 12-18-2006 10:51 AM | |
