Old 03-28-2005, 06:17 AM
Andy Andy is offline
Rep: 41 Posts: 177
Refastening clinker hull
Hi. I am about to refasten the hull of my clinker built Yachting World Dayboat and was wondering if I should go up a size when replacing the square sectioned copper nails and domed roves, or stick with the size currently in the hull. Any boatbuilders out there know which is normally done?
Andy
Old 03-28-2005, 09:02 AM
Robert Gainer Robert Gainer is offline
Designer/Builder
Rep: 44 Posts: 142
Why are you removing the old rivets? They are copper and very soft; you can tighten them instead of replacing them. If you need to replace them and the hole is still good, just use the same size.
Robert Gainer
Old 03-28-2005, 01:39 PM
Rep: 41 Posts: 177
hi Robert, thanks for your reply. many of the roves are now just red powder, so it seems like a good idea to replace them. i think the holes are ok, so i'll try your suggestion of using the same size again.
Andy
Old 03-29-2005, 10:36 PM
Rep: 1397 Posts: 7,216
If the hole is good you can stay with the same size. I doubt they are though. The corrosion in the metal usually produces chemicals that attack the wood. If you use a larger size, keep them as small as possible.
Hull speed Mike D Boat Design 33 02-27-2011 02:20 AM
Jet Drive Jet Drives 15 12-18-2006 10:51 AM
