Old 11-18-2008, 08:02 AM
johntec1 johntec1 is offline
Rep: 10 Posts: 2
Redecking Pontoon Boat
Our community recently purchased a 1984 24 ft pontoon to convert to a floating platform/observation deck to install adjacent to our dock. We removed the carpet and the deck is weathered and cracked. Can we cover it with 5/4 decking boards so it has the same appearance as our dock? Do we need to provide a 2 x 4 spacer between the old pywood and the decking boards?
What are your thoughts of using ACX treated plywood for this application?
Old 11-18-2008, 08:51 AM
PAR PAR is online now
Rep: 3125 Posts: 9,403
Yes, you can install those planks on the pontoon boat. An air gap is a good idea, between the plywood deck and the new decking material. Instead of 2x4's use 1x2's to save weight and money. Without this gap, moisture will collect between the plywood and new 5/4's stuff and rot will be the eventual result.
If replacing the old decking with new, PT plywood is a good choice. PT solid lumber (the 5/4's stock you mentioned) is also a good idea and both can be treated as the rest of your decking is.
Old 11-18-2008, 11:55 PM
Figgy's Avatar
Figgy Figgy is offline
Rep: 88 Posts: 315
Seconded. I think this is your best course of action for the look you want.
Imagination is more important than knowledge.
-Einstein
pontoon boat pindzia Boat Design 0 02-21-2008 09:17 AM
Newby question regarding Epoxy and fiberglass redecking and plywood choices baranx4 Boatbuilding 3 03-05-2007 07:55 AM
pontoon boat cat chaser Boatbuilding 51 11-01-2006 01:32 PM
Wood or fiberglass for redecking? GlassGuy650 Boatbuilding 6 11-23-2005 11:00 PM
8' pontoon boat Boatbuilding 16 04-30-2005 08:56 AM
