Old 09-06-2004, 10:21 PM
daniel k daniel k is offline
Rep: 10 Posts: 9
ready to paint?
I have finally finished building my "test" project, a 11'4" plywood skiff. My question is this, everything is glassed but now I need to smooth everything out before I paint. Is bondo acceptable for this, or do I need to use epoxy with a fairing additive? Thanks for any help!
Old 09-07-2004, 12:47 AM
Rep: 472 Posts: 615
On epoxy it's better to stay with epoxy or polyurethane. Polyester compounds do not cure well on epoxy (possibility of inhibition of the curing reaction by the amines of the epoxy), suck water and you have the risk of ruining all your paint job.
The best is to use an additive for fairing (phenolic microballoons for example) in your epoxy. If the quantity of fairing is small polyurethane fairing compound are very good and very easy to water sand, it's pretty expensive but very effective and saves a lot of time. I use it because it has an extraordinary ability of "feather edge" filling even the smallest scratch.
All fairing job must be well sealed with the primary before painting.
Old 09-10-2004, 05:33 PM
pungolee pungolee is offline
Rep: 34 Posts: 90
I like epoxy plumbers putty roll(sold at most auto parts stores)Roll it between your fingers,pack it in,wait a little while and shave it off with a good spatula or flatblade.Its tuff!
Old 09-10-2004, 11:35 PM
Rep: 1397 Posts: 7,216
If all you need is smoothing, a high build primer is easy. You can spray it on.
Topsides & Deck Paint Question Chris Krumm Materials 3 08-27-2005 08:44 PM
Paint question over epoxy zember311 Boatbuilding 5 11-26-2004 03:22 PM
Master Paint Craftsperson Daniel Fenton Services & Employment 0 10-31-2004 07:55 PM
what to use for filler? smoothing before paint LKJR Boatbuilding 5 08-25-2004 09:16 AM
I need HELP! AWLGRIP PAINT OVER GELCOAT chkmahow Materials 2 06-27-2004 12:14 AM
