| Pulling out cut nails Is there any way to pull out cut nails without hacking a hole around them to remove the plank. |
| You can just drill one hole right next to it and bend it to the hole, but this is what you try to avoid?
__________________ |
| The only way I've found is to wiggle it about a bit to loosen to the nail, then get a pair of pliers or pincers on the head, takes forever but leaves the smallest holes! - depends what your after - the nail or the wood! There's tons of the buggers in Kernow me 'ansom |
| copper nails and roves removal | Andy | Wooden Boat Building and Restoration | 7 | 05-04-2006 09:58 AM |
| Okay to cut stringers? | forestjohnson | Fiberglass and Composite Boat Building | 4 | 01-21-2006 12:06 PM |
| How to trace and cut bulkheads | ath | Sailboats | 18 | 06-10-2005 03:43 AM |
| boat tilt and pulling | Logan1500 | Powerboats | 6 | 07-19-2004 03:14 PM |
| Molding pulling away | Logan1500 | Powerboats | 1 | 05-24-2004 06:20 AM |
