#76
| If you paint it with a copper based wood preservative it will retard rot for a very long time.
__________________ Hoyt Lighting is very selective and will not strike crap. Wynand N http://www.genocidewatch.org/southafrica.html http://www.saabc.net/ |
#77
| Never-ending supply of briggs? http://cgi.ebay.com/ebaymotors/VINTA...item414ca0510b If I get that red one, I hope it runs this good or better. http://www.youtube.com/watch?v=3rgQY...eature=related CU later |
#78
| Would it last longer of I did this to it? http://www.youtube.com/watch?v=zhmZO...eature=related Well that's a stupid question! of course it would with lower rpm! I don't really see the point in doing that though, unless you want more momentum and slower idling. Would you suggest doing it though? just give me your opinion on the matter please. |
#79
| I think it is cool, and you might get better torque.
#80
| My final question is buy or no buy. I didn't ask those questions because it was too late and by the time the guy got back with the answers the bid would've ended. So buy or no buy. I understand I am taking a risk doing that, but it is a risk I am willing to take. BID ENDS IN THREE HOURS!!! |
#81
If you can get it for $19.99 plus shipping, it's probably worth the money--if you're sure you're going to use it. But if your first bid says "reserve not met," I'd drop it. They are easy to work on, if you have any mechanical aptitude, especially if you buy a Chilton's repair manual for small engines. At least 90% of the time, it's just a carburator problem.
__________________ There's a difference between keeping an open mind, and letting the wind whistle between your ears... |
#82
| You sound kinda negative on your first sentence .Okay thank you for your advice. I know what happens if the carburetor is screwed up. It backfires. I could just adjust the fuel/air ratio or change the fuel filter if it does backfire. My first bid is going to be $20.00. |
#83
#84
| The worst thing would be a cracked cylinder.
#85
| Never personally had that happen to me, although there's no doubt it can. After carburators and spark plugs, the most common (and most aggravating) problem I've had is surging or 'hunting.' That usually traces to a bad governor spring...or more likely, someone who had the carburator off hooking the spring back in the wrong hole.
#86
| Though I don't have much experience with outboard motors..me and a buddy picked a up a distressed 26' sailboat for free back in '04 hurricane season here in FLA...it was a Pearson 26...the guys who owned it had let her go and her cockpit drain hoses which ran through the cabin before draining out were old and developed leaks and filled the cabin with about 250 gallons of mostly rainwater...Since we both worked for a plumbing co..., we grabbed the jetter with a reverse head and sucked out the water...she was lying in sand..keel buried about 10' from a seawall and on the hard...Hurricane Charlie was off of Ft Myers and heading due north and coming right at us...my roomate Jason had got title to the boat after the Salvation army...who the two dudes "bequeathed" her to originally....didn't have a way to or couldn't salvage this boat....we got her pumped out and tied off to a mooring in the manmade cove near my house.We took the 9.9 yamaha into our shop.....blown head gasket...pretty easy fix...she ran great ...for a few weeks...we did a couple good sails....then Hurricane Frances hit...she moved the boat off mooring...just enough that our 9.9 Yamaha kissed the seawall... probably for half the storm...repeatedly.....El smasho....we did have one great nighttime summer sail on her in Sarasota bay before Frances hit...that summer was memorable...
__________________ ] |
#87
I used to just let it go, like I did with folks who said the same thing in Oklahoma (AKA Tornado Alley) when I was roughnecking on oil rigs there.
#88
| mgriffin, why don't you drop in on your local lawnmower shop and tell him what you are looking for? He might be able to "match" the internet deal with something off his "scrap" pile. Good luck. ![]()
| Unnecessary Complications is 99.99% complete | BHOFM | Wooden Boat Building and Restoration | 8 | 06-07-2009 06:36 AM |
| Newbie here with newbie question. Marine plywood or plywood? | photojunky | Wooden Boat Building and Restoration | 30 | 07-23-2007 06:41 AM |
| Plywood | desertgoldhound | Materials | 24 | 09-04-2006 11:44 AM |
| Calculating draft and other complications | HUM469 | Boat Design | 11 | 08-01-2006 02:16 PM |
| Looking for plywood | russ lepisto | Wooden Boat Building and Restoration | 14 | 05-03-2004 08:58 AM |
