  #61
Old 01-30-2010, 05:17 PM
mgriffin mgriffin is offline
Previous Member
Rep: 92 Posts: 122
Originally Posted by PAR View Post
There are several assumsions being made, before a design is actually selected.
I think the nesting "freighter" is a poor fit for Michael. It will be heavy, difficult to transport, take considerably more material to build, take considerably more time to build, will have limited maneuverability and limited usefulness.
Yes, you can skip 'glass, 'glass tape and epoxy all together, though you'll need a special design for this.
How long it lasts is subject directly to the care you provide. Given reasonable care, it could last a few decades, of course it will receive minor repairs and upgrades along the way. Given zero care it could last a few years.
Don't jump on a design until you define what the boat's use will be and most importantly, what your desires in the boat are.
You've switched from a mini tug boat to a camp cruiser to a houseboat to a weird contrivance of a freighter/push boat. This level of indecision suggests you're still trying to figure out what you want and need. In other words, keep looking and defining your goals and needs. You can just as easily build a boat that you'll hate to use as one you just love. This research now, will pay off huge come time to launch this puppy, so don't short change yourself, just to say you've selected a design.
You have made a very good point PAR, and ever since I decided to try and build a boat, I have searched for a certain type of boat. It meets all of my requirements which are these:
1. It has to have a shallow draft
2. It has to have a high load capacity (at least 1000 lbs maximum capacity)
3. It has to have some freeboard so it can survive small waves
4. It has to have some rocker (at least 4 inches, which on the TIMS design is in the front half only)
5. It has to be slightly narrow, (4 feet wide)
It meets all of my requirements, and it will only be 16 feet long, so what can go wrong? I might as well tape the seams, I mean ow hard could that be?
Plywood and Such, Complications, etc.-tims-3-quater-view.jpg  Plywood and Such, Complications, etc.-towboat.jpg
  #62
Old 01-31-2010, 01:24 PM
Previous Member
Rep: 92 Posts: 122
I understand what you are saying, but I am going to build only TWO sections, which is around 6 sheets of ply if I build a cabin on it, and it will only be 16 feet long if I build TWO sections like I said above. Front half and back half. It's that simple.
  #63
Old 01-31-2010, 09:40 PM
Wayne Grabow Wayne Grabow is offline
Rep: 260 Posts: 139
This was my first build which I used on the Platte River.
  #64
Old 02-01-2010, 06:01 PM
Previous Member
Rep: 92 Posts: 122
How old were you when you did your first build Wayne?
I hope to be fourteen when I build my first boat. I turn fourteen this month.
  #65
Old 02-01-2010, 09:20 PM
Rep: 260 Posts: 139
Michael, I was 28 when I built that boat. You are definitely starting young. Be careful about boatbuilding; it can be addictive. I am now building my seventh boat.
That 16' boat was built of 1/4" fir AB plywood over a frame, bonded with resorcinal glue, and with fiberglass tape on the seams. It was light enough to car-top; and well-suited to the wide, shallow Platte River.
Good luck with your plans.
  #66
Old 02-03-2010, 03:54 PM
Previous Member
Rep: 92 Posts: 122
If I do go inboard, then should I buy this?
http://cgi.ebay.com/2-5-hp-Briggs-an...item1e5a38f17e
  #67
Old 02-03-2010, 04:03 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Mad Scientist
Rep: 1786 Posts: 2,985
Hi, mgriffin,
How old is the engine?
How many hours has it been run?
Was it maintained?
Can it be fitted with a backfire flame arrester?
Ask these questions. Price is not bad. You will need the flame arrester for safety, especially if the hull is enclosed where gas fumes can accumulate.
Hoyt
Lighting is very selective and will not strike crap. Wynand N
http://www.genocidewatch.org/southafrica.html http://www.saabc.net/
  #68
Old 02-03-2010, 04:14 PM
troy2000's Avatar
troy2000 troy2000 is offline
Rep: 1578 Posts: 1,153
You know, I have a bigger version of that engine buried in a shed at the back of my property, on an old power reel mower. Unless some thieving little scumbag has stolen it, of course. They've been vacuuming up anything they find in the neighborhood lately, and selling it to a new scrap dealer who opened up down the road.
I haven't looked at it for a while, but I think it's about a 5-hp motor. Would it be feasible to do some sort of inboard power on a sharpie with it?
There's a difference between keeping an open mind, and letting the wind whistle between your ears...
  #69
Old 02-03-2010, 04:18 PM
hoytedow's Avatar
Mad Scientist
I have seen a similar engine run a paddle wheel. Why not a prop shaft?
Hoyt
  #70
Old 02-03-2010, 04:20 PM
troy2000's Avatar
Maybe I could do a paddlewheel Sharpie.
Or not.....
  #71
Old 02-03-2010, 04:26 PM
hoytedow's Avatar
Mad Scientist
Or not.....
You will grab attention, and a lot of laughter, most of it good-natured.
Hoyt
  #72
Old 02-03-2010, 05:03 PM
Previous Member
Rep: 92 Posts: 122
I wouldn't laugh, I would be in my boat blowing past your boat, laughing my ass off as I pass you multiple times!
(Good natured humor eh? )
Hey look what I found! talk about THUNK...THUNK..THUNK..THUNKTHUNK at 1:34!
http://www.youtube.com/watch?v=jn5PA...eature=related
wish you had one now? well it would be good for stationary, IDK about an inboard...
  #73
Old 02-03-2010, 05:05 PM
hoytedow's Avatar
Mad Scientist
Slight contradiction, but I get your drift.
Hoyt
  #74
Old 02-03-2010, 05:11 PM
Previous Member
Rep: 92 Posts: 122
yeah, I wouldn't want a paddle wheeler unless I had a steam engine and a perfectly flat bottomed hull! The advantage of paddle wheelers is they can go where no other boat can go. Well, that and they're pretty awesome looking.
BTW, my hull will not be enclosed.
If I remembered my evil-bay account, I would ask those questions. I'll have to ask my mom if she remembers my account username and passcode. I guess it's a good thing that the guy selling it has 100% positive feedback at least!
  #75
Old 02-03-2010, 05:20 PM
rasorinc rasorinc is offline
Rep: 682 Posts: 1,130
A simple light weight layer of fiberglass assures you the bottom and sides are waterproof. I would never omit this simple process on a boat such as you posted. An all mahogony boat, yes but not yours. Why risk the beginning of an instant rotting process after you worked so hard to make it.
Unnecessary Complications is 99.99% complete BHOFM Wooden Boat Building and Restoration 8 06-07-2009 06:36 AM
Newbie here with newbie question. Marine plywood or plywood? photojunky Wooden Boat Building and Restoration 30 07-23-2007 06:41 AM
Plywood desertgoldhound Materials 24 09-04-2006 11:44 AM
Calculating draft and other complications HUM469 Boat Design 11 08-01-2006 02:16 PM
Looking for plywood russ lepisto Wooden Boat Building and Restoration 14 05-03-2004 08:58 AM
