| I did the first one today using the router jig. I did 10:1 just cause the maths is dead easy with a pencil in the shop... and heck whats 20mm or so more ply wood and glue. The jig was a stuff around to setup so that it cuts right, but once set up cutting the joints took very little time and its accurate. Cheers MBz |
| Yep, that's my issue with the jigs MBz. The setup time can be longer then the actual tool in hand time, sometimes much longer. Unless a bunch of planking scarfs (or something) are necessary, I'll stick with wood butcher's friend, a chisel and a power plane. I've preformed this "race" a few times with kids in the shop that think jigs are cool and hand tools for old timers. They set up the jig and I cut the scarf before they load the stock or start the tool. You got'a make them humble or they'll get uppity on 'ya. Good for you and your sucess. |
| LOL... In my case its just substituting time for skill, thats a trade I need to make ![]() |
| A question Par, If you had to patch a plywood boat, say a 200mm square patch. What sort of angle would you attempt to scarf ? Given the limitations of such a situation I would be tempted to stick a router in the hole with the flattest angle I can find, but say 45% and then epoxy glue a patch in, with maybe a thinner backing plate glued in place. What does a pro do? This is purely hypothetical. Cheers MBz |
| I'd use a grinder with 16 or 24 grit and back the surrounding surfaces off about 8 or 10:1 then dry fit a patch with similar tapered edges. A few times around and it'll be close enough for wood butcher's friend to make nice. Fill, paint and the owner will never know. Damn, I'm usually the owner . . . A 45 degree angle will crack out pretty quick if any stress is on it. |
| square is a GOOD point too for the patch ( even though i think round would even be harder to fit,,,,,i hate wood ) because when it comes time to paint it,,no matter WHAT you do,,, you'll ALWAYS see the round patch,,,,even a small drill hole will show. ,,hehe......sorry Beanzy and Par ,,,hehe ,,only thing i know bout wood ,, is to burn it in the winter to stay warm,, and i was feeling a little left out..,,,:sob:,,,,:sigh:,,,,so,,,,i only knew bout ,,,welll,,, ![]() hahaha ![]()
__________________ hehe ,,,,,Jim------> |
| OK, thanks PAR, I was wondering if you'd still go for the 8:1 ratio. Jim... ya boil it and eat it... try some ![]() Cheers MBz |
| Yep, I'd still feather back at least 8:1 on plywood planking. It doesn't have to be particularly precise when using epoxy. In fact, it's better if it isn't. Jim, my repairs don't show, even years later. Just use enough goo and no crisp edges on the affected area. |
| something for you Beanz not mine, but am close to starting a build that has many joints here is the link there are some nice pics http://westsystem.com/ewmag/18/plywood.html Plywood basics By J. R. Watson Since so many projects in Epoxyworks incorporate plywood, we felt it might be valuable to discuss briefly the types of plywood and some construction methods best suited to it. It's easy to understand why people like plywood and choose it for so many projects: it is readily available, comes in convenient sheets (typically 4'×8'), is pretty light for its stiffness and strength (1/8" plywood weighs about 11 lb per 32 sq ft panel), and is a bargain when compared to the price of many composite panels. However, plywood also has its weak points. There are limits regarding shape development because plywood can be compounded (bent in two directions at once) very little. In addition, plywood contains end grain on all its edges, which makes it susceptible to moisture migration and damage. So while we've had good success in a diversity of projects using plywood, it's important to consider these guidelines. Understand plywood grades All plywood is graded based on the quality of the veneers and the size and number of permissible voids and patches. Grades A-C are the most common. To be suitable for marine construction, panels must be made with waterproof glue and marked as exterior plywood (EXT) or marine plywood. As a general rule for boat projects, use marine-grade plywood because the wood used to make it is of higher quality with smaller voids and fewer patches. Inner veneers are also of higher quality, grade B or better. Marine plywood is therefore more stable, has less potential for checking, and the overall strength and stiffness are better than exterior plywood. When you consider the overall cost of a project, the price for marine grade plywood is well worth it. While AC exterior plywood could be used on "low cost" boats, filling all the knots and voids may cost more in time and materials than if you had bought better grade plywood. Aircraft grade plywood is also very high quality and might be appropriate in specialized applications, such as a cored panel wing mast. Some builders have used door skins (3mm thick) when making a laminate of multiple layers, but you need to make sure they are glued with exterior grade glue and are of adequate quality. You should not use plywood underlayment for boat building because of its poor quality. U.S. marine grade plywood must meet U.S. Products Standard PS 1-74 (applies only to softwood plywood). Species: Douglas fir No 1 or western larch. Glue: waterproof. Face and back veneers A-A, A-B, B-B smooth cut and free of knots, pitch pockets and open splits and other open defects. Inner plies B or better. Repairs: no more than 9 repairs allowed on A faces in a 4×8 sheet. Marine grade for tropical hardwoods must meet British Standard Specification BS 1088. Species: untreated tropical hardwood veneers with suitable level of resistance to fungal attack. Glue: waterproof glue. Face veneers free of knots and other than solid pin knots no more than 6 in any 1 square foot area. Core veneers shall be the same as those for face veneers. No gaps in faces. In core, not more than one gap no wider than .5mm. Face veneers if three-ply construction shall not be thinner than " of the total thickness. Aircraft grade plywood meets all specifications of MIL-P-6070, which calls for shear testing after immersion in boiling water for three hours. It is made of imported African mahogany or American birch veneer laminated in a hot press to a hardwood core of poplar or basswood with waterproof glue. Check the plies Plywood typically comes in an odd number of plies in order to achieve balanced construction. The number of veneers on each side of the core layer must be equal in number (and thickness) or the panel may warp. The plies should be parallel to one another with alternating layers set at 90° or warping can occur. When you buy plywood, lay the sheet down on the ground. If it's curled or twisted and doesn't lie flat, don't buy it. Select plywood where the total thickness of the two outer plies equals the thickness of the core. Avoid 'cigar box' stock where a thick core is sheathed with thin face veneers. Most plywood under 1/4" (6mm) is three ply construction. One quarter inch plywood and thicker is available in 5 or more plies. More plies are better because the panel is more dimensionally stable, less likely to warp and stiffer than three-ply. Know the wood species Most marine grade plywood is made from tropical hardwoods, like African mahogany, sapele, utile, and okoume. Some wood species are more durable than others. Coating surfaces (especially exposed end grain) with epoxy greatly protects less durable woods from the harmful effects of moisture. While okoume is considered a non-durable species, we have had good long-term results with it. Much of this is the result of thorough coating with WEST SYSTEM® epoxy and careful maintenance of the finished boat, including ventilation and prompt repairs. The biggest challenge with Douglas fir plywood is the propensity of its outer (face) veneer to check, that is, split along the grain. This is especially true when the outer surface forms a curve perpendicular to the face grain. Covering fir plywood with 6 oz fiberglass fabric is mandatory to contain the checking. Limitations of pressure-treated plywood Many people ask about the value of pressure treated plywood. Often, pressure treated plywood is heavily warped. This is primarily the result of the high temperature and rapid moisture take up during processing. Some plywood delaminates during the process. In addition, some pressure treating methods incorporate water repellant materials. These materials can easily jeopardize bonding so you won't be able to glue or paint the plywood successfully. Generally speaking, pressure treated plywood may be acceptable for house projects but not for boats. Select the right plywood for the project With the many types of plywood available, it is important to choose and combine the types and thicknesses of plywood best suited to your project. For the kind of projects typically described in Epoxyworks, strength, durability and weight are primary considerations. So we usually choose somewhat specialized plywood to meet the particular requirements of the project. For example, on a wing mast I built twenty years ago, I was after light weight and flexibility. So, I selected plywood that would allow me to bend the laminate to a tight radius foil section: aircraft grade 1/16" birch on the mast's exterior, and 1/64" (3 ply) on the interior, with a honeycomb core. On a current project, I've chosen a 9 mm teak-faced plywood to replace the live well and wet locker hatches on my Mako Angler. I wanted the teak finish and flat, hinged panels. So I chose a plywood with a teak face, stiffness and dimensional stability. The point is to select carefully the best plywood for your project. Building your own plywood Some folks opt to build their own plywood by laying up multiple layers of sliced or peeled veneer. You need a suitable flat surface and a method of applying pressure until the adhesive that joins the layers has cured. Building your own plywood rarely saves money and the panels are often heavy. However, you can tailor your choice of a face veneer and it is possible to make some really beautiful panels. You also can make the panels whatever size you want. When you laminate a hull, as in cold-molded construction, you are actually making plywood to a specific shape, that of a boat hull (see Laminated construction gives lasting value). Joining plywood panels You can join plywood panels in a number of ways if you need sizes greater than standard ones. Scarf joints are the best approach for strength and weight. (If you order 16' long panels, offered by some plywood suppliers, the panels are simply scarfed together, but you will pay a premium both for the material and the shipping.) Gougeon Brothers, Inc. does offer a custom attachment (875 Scarffer™) that fits onto a circular saw. This tool makes scarfing plywood panels of 3/8" thickness or less quick and accurate. You can also fashion scarfs with a plane and/or grinder. The rule is to create a bevel 8 times the thickness of the plywood. Panels can also be joined with butt blocks, but this has the potential for exposing end grain at the butt. We like to dish out the butted area similar to a scarf and bond in fiberglass cloth. Construction methods with plywood Plywood is ideal for several construction methods. The most common is "stitch and glue" construction where panels are cut to a designed shape and temporarily joined with wire or plastic ties. Then you apply epoxy fillets and fiberglass tape to permanently join the structure in a rigid shape. (See Building prams) Plywood has also been used successfully to build lightweight lapstrake boats. Tom Hill described this in Ultra Light Boatbuilding (available through International Marine Publications, phone 207-236-4837). Probably the most extreme shapes can be gotten via "tortured," also known as developed plywood construction, where the plywood is actually compounded. This construction method is limited to thin plywood and hulls with modest shapes, most typically multihull craft. Designing your own plywood boat used to be very challenging because if you introduced excessive compounding, you could have trouble laying out the plywood to the shape. With stitch and glue construction, it is extremely difficult to predict panel shapes. Now, however, some excellent software is available so you can get accurate offsets for the true shapes of panels. Two that we have used are Plyboats, 714-840-7284, www.plyboats.com and New Wave Systems, Inc., 401-423-1852, www.newavesys.com. Epoxyworks 18 / Fall 2001 |
#25
| Thanks LJ... I will explore. ![]() |
#26
| Lessons learned.... 1. Make sure that the jig setup is totally clean prior to putting ply down. The smallest particle can have quite an effect. 2. Although the router is very accurate take the joint to within about 1 mm of the final desired cut and take the rest back with a sanding machine. This gives better control over the outcome. 3. Clamp the long end of the join and set the short end up against a backstop. This makes it easy to drop and clamp the short end in place without having to worry too much about placement, the backstop pretty well assures it lands where you dry fitted it. 4. A 10:1 join feels damn solid.... (as I am sure that a 8:1 does!)Cheers MBz |
#27
#28
| well we can all plan, I have not got a shed, now, last scarfing did was on some chairs, two pieces 40x40 box one on top one under, held the joint, , but slid all over the place Miss my workshop are you using an end mill bit, in that router? and wherever you live do you have square drive screws? you don't see them in Au but in NZ we use nothing but, they stay in the driver at anything but down angles, adn dont slip, bestest invention since sliced bread Best high ten ss seems come from USA, many tai screws like cheese |
#29
| Scarfing plywood is easiest with a 3 or 4 inch power plane, simply keep the glue lines parallel and evenly spaced as the wood is constructed. Hand finished with a standard jack plane , sharpened correctly of course, and the job is finished long before any jig is set up and played with. Even when we do a pallet of ply scarfs, the power plane is the tool of choice, not a jig. We do about 4 or 5 sheets at a time staggered stacks, and hit with the planer. Please understand, the jig is very accurate, no doubt and it has its uses, but in reality the epoxy takes up and needs to be there to create the strongest joint
#30
| Lubber, that's exactly what I've found. After hundreds of scarfs, the cleanest, fastest and most likely to fit in tight places (such as doing plank scarfs on the boat) is a plane, power if you have the room to swing it, hand if not. I've done many scrafs on lapstrake planking, while I'm hanging planks. No jig works in this application, just a sharp hand plane and chisel. On the bench, you have some options, but unless you're plowing through a dozen similar dimension scarfs, in one session, the jigs seem to take too long to set up, are bulky and require clever clamping arrangements to the stock doesn't cup, move or other wise ruin your day. The circular saw jig I show above is the only one I use most of the time, unless I need a precision scarf in a bit of bright work. There's no set up, just clamp the work and slide the saw down the guide. It was originally intended for full length (8') scarfs, when I was planking up a big boat and needed to cover large areas of hull with full (or nearly so) sheets of plywood. It works for short scarfs too. |
| U-joint, CV-joint, Thompson coupling | brian eiland | Propulsion | 17 | 02-09-2012 12:53 PM |
| 1:78 ratio vs. 1.47:1 ratio ... which to choose? | ezfriday | Propulsion | 18 | 02-18-2006 09:21 PM |
| Sandwich hull panel to plywood bulkhead T joint??? | leegrace | Fiberglass and Composite Boat Building | 4 | 02-01-2006 09:42 PM |
| Joint methods | JosephKeel | Wooden Boat Building and Restoration | 10 | 08-10-2004 04:13 AM |
