| Plywood hull Hello, I am going to try to restore a 65 chris craft cavalier30'. I want to strip the plywood hull and recoat it. Do i strip it to the wood or the paper coating? What would be the best way to do this. Any help would be great. Thanks Dave |
| We stripped my 69 cavalier to the paper with a chemical stripper for epoxy/paint and flat blade scapers. It took a couple of coats to remove the marine paint. I didn't do it but it looked like alot of work. The transom is not paper covered plywood (mine was painted). If i can help lemeno. Note: This week i'll be fiberglassing the cabintop. |
| Hey thanks for the reply. What do you think of that cpes stuff? Or is that over rated. The boat is very solid. i just have to fix a couple spots. Thanks Dave |
| No Problem, anytime. I couldn't say either way about cpes. I've been using laquer thinner up to 100% added to the resin/hardener mix. This is with the 150 grade resin at a 1:1 ratio. Just for treating...not glueing. I read extensively on the internet and this is what i ended up using. Solid boat. Yes. I've been out in some heavy weather with mine and was pleased so far. I particularly like surfing with her on a following sea. Have you started the refinishing yet? How's the transom ? Best. |
| 16 FT Plywood Hull | fredrosse | Wooden Boat Building and Restoration | 7 | 10-25-2010 08:42 PM |
| Repainting a plywood/epoxy hull | dave e | Wooden Boat Building and Restoration | 8 | 10-27-2005 11:52 AM |
| steel hull plywood deck | david embra | Boat Design | 1 | 08-30-2005 08:59 AM |
| Incorporating Kevlar into a plywood hull? | MarkNY | Wooden Boat Building and Restoration | 2 | 01-09-2005 04:39 AM |
| Steel and plywood hull? | pdvjak | Boatbuilding | 1 | 02-02-2003 12:12 AM |
