Old 12-08-2009, 04:02 PM
troy2000's Avatar
troy2000 troy2000 is offline
Rep: 1686 Posts: 1,240
Plywood: fasten to frames or stringers?
Years ago I read a piece on building boats out of plywood. I don't remember who wrote it or where I found it, but I do remember the author insisting that plywood sides and bottoms on a boat should never be fastened directly to frames or bulkheads. According to him, the only proper method was to run stringers fore and aft, and fasten the plywood only to the stringers.
I wouldn't guarantee it, but it seems to me he was writing back around the early sixties. And I believe there were photographs of a fairly small motorboat under construction.
Does anyone agree...disagree...think it doesn't matter?
Old 12-08-2009, 05:02 PM
Rep: 1493 Posts: 7,447
There have been a few boats built like that. However, saying that it is the only method is rather fanatical.
Old 12-08-2009, 05:58 PM
troy2000's Avatar
I wish I could remember who the author was. He was quite insistent about it. I think he believed fastening to a frame concentrated the stresses, or some such thing.
For some reason, I always thought I had read it in a Glen-L Marine how-to. But I just went and looked at their website, and that isn't what they say.
Old 12-08-2009, 06:17 PM
boat fan's Avatar
boat fan boat fan is offline
Rep: 357 Posts: 681
They ( Glen - L ) say this ...
Q: Why shouldn't sheet plywood planking be fastened to transverse frames?
A: The properly designed plywood planked hull incorporates as much as possible the principles of monocoque or "stress-skin" construction. Stitch-and-glue boats that depend upon glue bonded junctions reinforced with fiberglass tape often show pure adherence to such principles. However, not everyone is willing to trust their fate only to glue bonds; many still favor the extra security that fastenings and some internal framework can provide. After all, such construction has been proven strong and durable for generations whereas stitch-and-glue is still the new kid on the block.
But even when transverse frames are part of the design, it's the plywood skin that takes the stresses which are ultimately transferred to glued and/or fastened joints at panel edges. And if such panels are fastened across the grain to frames, localized stresses that can lead to failure of the panel can be generated. How so?
Consider a plywood panel curved in place around a hull as being analogous to corrugated cardboard applied in similar fashion with the corrugations running lengthwise. We can pin or tack such a cardboard panel in place all around the edges to hold it in place. But what happens to the cardboard if we perforate it with a bunch of fastening holes crosswise? When bent in place, it would fold and break about the perforations.
The same thing can happen in a sheet of plywood. Placing a row of fastenings across the plywood panels grain can weaken a panel and create a similar condition, especially so when the panel is also under tension due to bending. Conditions are exacerbated on the higher-speed powerboat where panel loads are greatly magnified due to slamming loads while planing.
In short, while frames on the plywood boat may contact planking and be glued at such points, ordinarily such contact is not actually necessary and in fact, frames can usually be relieved from such contact without detriment. In reality, it's the longitudinal members doing most of the work and this is why planking panels are preferably fastened only to these and at the ends of panels and NOT to frames between.
There was a builder of high end Italian power boats that said he would never do it ...stress risers .
He also said not to notch stringers into frames for the same reason.
Don`t remember who he was either ...
How big a reproduction are you thinking and do you have crew and money dripping off your butt?( PAR2009)
Old 12-08-2009, 06:52 PM
troy2000's Avatar
Then maybe it was a Glen-L publication I read it in, way back when. But if I remember right, the recommendation at the time was quite a bit stronger than "preferably."
I don't think I'll be building with plywood thin enough, or fastenings spaced closely enough, to worry about it.
Old 12-08-2009, 06:58 PM
wardd wardd is offline
Rep: 443 Posts: 925
build the skin then fit the frame to it
the basket approach appeals to me
Old 12-08-2009, 07:11 PM
boat fan's Avatar
Rep: 357 Posts: 681
Troy ..these guys don`t like it either .....
Personally , I would build this way.
Nexus Marine Corporation
http://www.google.com.au/url?sa=t&so...rxztWeoCZt061w
The chine and all stringers have now been installed. All these members were precoated with epoxy resin before they were installed. The stringers have been glued and screwed to the outside of the frames. The stringers are not notched into the frames. This prevents "hard spots" in the planking. It's stronger this way. The aft cabin bulkhead and engine room bulkhead have to be watertight, so we have blocked between the stringers just on those bulkheads.
Here we are looking at the inside of the transom, portside. Again , with the bottom stringers passing over the aftmost frame and notching into the transom frame only.
Old 12-08-2009, 07:36 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
Everything depends upon the design, the type of boat, size, etc.. Plywood is manufactured in several ways that vary in cross-grain stiffness. Imagine building a house floor using the plywood with the grain running parallel to the joists below. I've done this with plywood that had poor cross-grain strength and within a short time it sagged from normal loads.
A flattish hull shape with wide panels (such as a jon boat) could really use some cross-frames in contact with the plywood. On the other hand, a more curvacious hull like a nutshell pram is plenty strong enough with no cross-frames. It also matters, as said, if the plywood is stiff across the grain seen on the outside plys. It matters how robust the plywood relative to the boat's length. Nothing is as simple as to state all boats benefit from frames set in from the stringers.
Old 12-08-2009, 07:39 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1874 Posts: 3,357
One reason not to screw skin to frame is that quite often the frame is nothing more than plywood, which does not take a screw in the edge well.
Hoyt
Old 12-08-2009, 07:42 PM
boat fan's Avatar
Rep: 357 Posts: 681
Yes , quite true.
Stringer spacing has a lot to do with it also.( more stingers , thin skin ) ?
or opposite .
If you look at that power boat , the stringers are wider ( 2x ? ) and more closely spaced on the bottom.
Makes sense .
Troy ...your sharpie will have a relatively heavy bottom , no ?
As sharpies benefit by having a heavier bottom , ( 2 x layers ( or more ?) bottom planking ? ) I don`t believe there would be any issues here , regarding sufficient strength.
Water would collect easier in the lowest part of the " bilge " to mop up .....
I would just run the stringers over the frames.
Easier , faster build.
Better also for a trailer sharpie I think.
I noticed that they ( Nexus ) build their dory that way as well.
Should be good for you too.
What do you think ?
Old 12-08-2009, 07:58 PM
jimm's Avatar
jimm jimm is offline
designer MID
Rep: 23 Posts: 37
In boats I have designed, I am familiar with (30' to !30' range) longitudinal and athrotship frames comprise the structure below the waterline. bulkheads and soles constitute reinforcement to the hull above the waterline and are bonded wherever possible to the hull and deck to reinforce its strength. Ths includes seating structure and counter tops.
Old 12-08-2009, 09:43 PM
alan white's Avatar
Dories are a good example of transverse framing in full contact with the hull. The bottom is very thick and there are no stringers. Not even a keelson. This is true whether of plywood or boards.
I believe very light structures do benefit from recessed transverse frames and many light stringers. When going very light, such as building a plywood skinned kayak, the web frames are usually recessed. This prevents hard spots and localized stresses. Hydrodynamically, very (1/8") thin plywood would act like a stiff fabric. Cross-framing ridges would not flex inward, whiile longintudinal dishing with recessed frames would have better flow characteristics.
Old 12-08-2009, 10:21 PM
boat fan's Avatar
Rep: 357 Posts: 681
Not on this one Alan :
No frame contact. Stringers on sides and bottom.
Like you say dories usually have trans. frames in contact with hull...no stringers ....
Unusual for a dory , but there it is.
I think the key here being planing dory.....
I would not build a sharpie without a keelson.
Custom wood 23' Planing Dory
Old 12-08-2009, 11:02 PM
peter radclyffe's Avatar
peter radclyffe peter radclyffe is offline
Rep: 576 Posts: 1,066
it shows how weak plywood is
Old 12-08-2009, 11:06 PM
boat fan's Avatar
Rep: 357 Posts: 681
Huh ?
plywood transom/stringers? stilloutoffocus Materials 8 06-17-2009 11:21 AM
Marine plywood for frames wudenbote Wooden Boat Building and Restoration 3 09-15-2008 05:50 PM
Letting Stringers & Chines "Stand Proud" from Transverse Frames timgoz Metal Boat Building 16 10-29-2006 09:05 AM
Bulkhead? to fasten or not to fasten. Deeman Fiberglass and Composite Boat Building 2 08-18-2006 03:00 PM
Stripping paint from stringers and frames boony Wooden Boat Building and Restoration 8 06-05-2006 09:05 PM
