Old 05-03-2009, 11:13 PM
woodrat woodrat is offline
Rep: 10 Posts: 15
I would be using it more in saltwater than fresh.
I think I will go ahead and strip it down when the weather gets reliably nice and see what I end up with. The hull seems very beefy, even overly so, compared to what the plans called for. The transom and the bottom are 1-1/2" thick, and the transom has a huge laminated knee between it and the keelson. And I plan on putting an offshore bracket on it for the outboard anyway. Unless I find some gawdawful rot or other hidden problems when I strip the sheathing off, I think this will make a solid fishing and camping boat in the end, for a lot less money than I could buy the equivalent boat for on the open market.
Thanks to all for the input.
Saturating Epoxy on Plywood Meanz Beanz Wooden Boat Building and Restoration 39 07-10-2008 09:08 AM
Peel Ply on plywood/Epoxy Triman Wooden Boat Building and Restoration 5 08-17-2007 10:07 AM
Newby question regarding Epoxy and fiberglass redecking and plywood choices baranx4 Boatbuilding 3 03-05-2007 08:55 AM
Epoxy and marine plywood micag Fiberglass and Composite Boat Building 0 07-17-2006 12:17 PM
Repainting a plywood/epoxy hull dave e Wooden Boat Building and Restoration 8 10-27-2005 11:52 AM
