Old 08-14-2007, 10:34 AM
Alixander Beck Alixander Beck is offline
Rep: 10 Posts: 55
Plywood Curiosity Question
Would you use non-marine grade ply encapsulated in epoxy for bulkhead sections of a small sailing dinghy?
If encapsulation was done well would it not protect the wood well enough to stop bilge water - which would be the most likely place for water penetration.
Old 08-14-2007, 11:28 AM
timgoz's Avatar
timgoz timgoz is offline
Rep: 262 Posts: 1,067
Alixander,
Do a forum search on plywood, marine ply, ect....
This issue has been dealt with numerous times. You will find a wealth of information.
Take care.
Tim
Old 08-14-2007, 11:45 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 604
Hi Alix
For a dingy non-marine ply would probably be ok. Test your resin to see if it'll stick first. Some ply's don't take or hold resin well. If you can ad some fiberglass when you encapsulate the bulkhead. You may well need "Limber Holes" to allow water to flow from one compartment of a boat to the next. These are usually put at the very bottom of the bulkhead so that when the boat is at rest the water can flow uninterrupted out of the compartment. For a dingy it isn't that important, just haul it up on the beach/dock and tip it over. If you cut limber holes remember to goop up the exposed core (plywood) with some epoxy to keep it from getting wet.
Good Luck
Rick
Old 08-14-2007, 12:30 PM
USCGRET/E8 USCGRET/E8 is offline
Senior Chief
Rep: 41 Posts: 164
Exterior fur ply should be fine. I would try to find some B C grade, so it's pretty and smooth on both sides, unless your going to paint it.
Old 08-14-2007, 01:05 PM
Rep: 10 Posts: 55
Thanks for the advice Gents.
Old 08-14-2007, 03:17 PM
Rep: 2891 Posts: 8,798
Make sure it's a WBP adhesive and not a type II (water resistant) adhesive. On exterior sheets it will be marked "continuous ground contact" (WBP glue) or "sheathing" (type II glue). A type II panel will eventually fail, if the bulkheads sit in pools of water, limbers or not. Encapsulation will help a type II sheet last a lot longer. Make great pains to insure the end grain (edges) and any holes, notches or cutouts are well coated with goo.
Old 08-14-2007, 03:45 PM
Rep: 10 Posts: 55
Thanks!
yes of course the end grain is the most important to seal....Water's favourite entry point.
Old 08-29-2007, 06:23 PM
chandler chandler is offline
Rep: 16 Posts: 378
How long do want it to last? If it's a dingy you probably only need a 1/2 sheet. Spend the extra money. Construction grade plywood gets worse by the day, voids, poor quality veneers, etc.
Stay away from the big box store hardwood plywood, it's all junk!
Plywood Shape question justen1984 Wooden Boat Building and Restoration 2 09-05-2007 11:11 PM
type of plywood question... bmack Wooden Boat Building and Restoration 7 07-29-2007 11:10 PM
Newbie here with newbie question. Marine plywood or plywood? photojunky Wooden Boat Building and Restoration 30 07-23-2007 06:41 AM
Just out of curiosity Ferdous Sailboats 7 03-26-2007 11:13 PM
Plywood question bearwen Wooden Boat Building and Restoration 15 11-08-2005 04:43 PM
