Old 06-06-2010, 07:20 AM
robertgrandbois robertgrandbois is offline
Rep: 10 Posts: 14
plywood or cedar strips?
I am restoring an old plywood boat. My wife says she would like to see it covered with cedar strip instead of plywood can that be done? I think it would be a much better looking boat.
Old 06-06-2010, 09:50 AM
alan white's Avatar
Rep: 1211 Posts: 3,325
Anything can be done though cedar strips have to be glassed inside and out. How do you do that where frames and stringers get in the way?
the answer is, depending on how much weight plays a role in the boat's usability, you may be able to install a thinner plywood first and then epoxy thin strips fore and aft (then epoxy/glass/varnish the exterior using a layer of light glass).
The result would be a strong and not too heavy, I think.
Old 06-06-2010, 08:23 PM
Rep: 10 Posts: 14
ok thanks i will go on with the original plan then tell the wife to stay out of my shop. It is my only peaceful retreat.
Old 06-07-2010, 10:54 AM
sean-nós's Avatar
sean-nós sean-nós is offline
Rep: 286 Posts: 103
On my build I will be covering the boat in 1/4" ply and then 1/4" by 4" planks of mahogany.
http://s753.photobucket.com/albums/x...er/crackerbox/
This is the way this was done and the look I am going for.
Old 06-14-2010, 06:53 PM
aka Terry Haines
Rep: 1814 Posts: 3,009
Some thoughts: the glass provides the cross-grain strength that the cedar strips lack. With a typical strip build the inside is smooth so glass can be applied to both sides. However a hundred years ago the cedar strips would have had many closely-spaced steam-bent ribs whcich would have done the same thing. So if you have frames inside, it seems to me that's got one side covered - metaphorically speaking - so the ply isn't necessary and only the outside needs to be glassed which would be a lot easier. Of course, this is all theoretical if you are half-way through the job by now!
Dances with Turkeys
tapered strips JackWhite Boat Design 15 10-14-2009 08:48 AM
Port Orford Cedar vs Western Red Cedar? Thomas Wick Wooden Boat Building and Restoration 23 09-16-2008 01:18 PM
Feature Strips on Cedar Planked Rowboat Plederman Wooden Boat Building and Restoration 4 07-10-2007 07:21 PM
Apple for strips? Neverbehind Materials 11 06-12-2006 03:02 PM
Longer Cedar strips doesitfloat Wooden Boat Building and Restoration 4 02-21-2005 08:58 AM
