| Plywood Catamaran Greetings fellow sailors! I am new to this forum and look forward to finding input on my first ever construction project. I am retired and had to let my Hunter 280 go due to lack of funds. My budget is quite small, but I would like to build a catamaran using the stitch and glue method.(sailboat that is). My objective is to end up with a boat capable of coastal cruising, perhaps 28 to 30 feet in length with possible crossings from Florida to the Bahamas. Has anyone experience building such a boat or Jim Brown Trimarans? I live on 4 acres in North Florida so space is not a problem, in fact if you want room to build your sailing vessel contact me. I would be building kind of piecemeal, that is, small amounts of plywood each month as budget permits(ouch! could be buried before I finish!). Thanks for your input and ideas. Pete |
| Look at Kurt Hugh's catalog. His designs might be exactly what you want. There is a "low" priced seller of marine ply in the bottom of florida. If you save your pennies and then place a big order the price per sheet will drop. happy building |
| thanks Appreciate the input and have sent for info from Kurt Hughes. It's a little intimidating as I have never built a boat before and don't want to overstep my abilities! Pete |
| If you can read a blue print, mix epoxy, use a jig saw, tolerate sanding ... you will have the same problems as the rest of us. smile |
| Probably the first thing to do is to write down a realistic budget. If you can't affford that Hunter, building a boat may be even more expensive.
__________________ Gonzo |
| Thank-you folks! I do appreciate the input from you all. In checking out Clarkcraft.com I found a Lively 28 with frame kit etc. which may be the best way to go for my limited budget. We'll see after I check out all the info I can find. petee |
| Do a Google search for a design called Gypsy by Richard Woods. He built the first one for £5000 in the early 90's, and it had rave reviews in a number of boating magazines! Andy |
| Go with Gonzo's idea. Maintaining a boat IS cheaper than building with no experience. Or, buy a small good boat and go out on the water with it whenever you please. A boat moving on water, is better than one upside down in a garage. |
| Dear Petee, I have started a Didi 26 and to complete boat at tip top condition will cost me around 15 grand |
| Use of plywood for internal structures | RubinB | Fiberglass and Composite Boat Building | 1 | 08-19-2005 11:59 AM |
| Boatbuilding plywood | rdbct | Wooden Boat Building and Restoration | 3 | 02-05-2005 06:12 PM |
| Join in a Co-operative Catamaran Build Venture! | Neven | Marketplace | 0 | 12-17-2004 02:20 AM |
| mahogany marine plywood structure? | blackspot | Materials | 13 | 10-06-2004 09:39 AM |
| Plywood specs from the user point of view | amitk | Materials | 0 | 10-04-2004 12:13 PM |
